steinerlein
RPi 3 B+ Wifi not working
Mon Mar 26, 2018 1:19 pm
Hey all,
I am trying to set up a headless pi. It downloaded and flashed raspbian stretch today. After adding a wpa_supplicant.conf in /boot the unit didn't connect to the network. I was able to activate ssh though and am now connected via ethernet.
iwlist wlan0 scan
returns:
wlan0     Failed to read scan data : Network is down
The content of
/etc/wpa_supplicant/wpa_supplicant.conf
is:
update_config=1
country=DE
network={
        ssid="xxx"
        psk="xxx"
looking for the wifi device over
lsusb
gives:
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Is the Hardware faulty?
procount
Re: RPi 3 B+ Wifi not working
Mon Mar 26, 2018 1:26 pm
The RPI3B+ wifi is connected via SDIO, not USB, so it won't be listed in lsusb.
There's some other threads about getting wifi working on a 3B+, involving rfkill, country codes and possible race conditions. The search box should turn them up.
pcmanbob
Mon Mar 26, 2018 1:36 pm
seeing as you have access via a wired connection run
sudo raspi-config
under localisation options select change wifi country and reboot, that should enable you wifi.
steinerlein
Mon Mar 26, 2018 1:41 pm
sudo raspi-config
I tried that, unfortunately it didn't help :(
pcmanbob
Mon Mar 26, 2018 1:49 pm
sudo raspi-config
Then I suggest you try.
sudo rfkill unblock wifi
steinerlein
Mon Mar 26, 2018 1:59 pm
without trying your suggestion I was able to resolve the issue by reflashing raspbian. I do wonder what went wrong, though! Thanks for the help anyway.
pcmanbob
Mon Mar 26, 2018 2:08 pm
Glad you got it working.
If you edit /etc/wpa_supplicant/wpa_supplicant.conf directly you need to run the rfkill command to unblock the wifi, if you place a copy of wpa_supplicant.conf in the small fat partition the same as you do when you enable ssh using the ssh.txt option and then boot your pi the wpa_supplicant.conf will be copied and assuming its all correct the wifi will be activated at the same time.
harthenry
Thu Nov 08, 2018 7:20 pm
With me, not only is the passphrase case sensitive but the SSID as well. Be sure to follow CoRRecT capitalization of your SSID
