Dubioz
Failed to start System Logging Service
Wed Mar 07, 2018 6:44 am
After rebooting my RPi 3 it seems that the rsyslogd service fails to start. I have tried the following:
- sudo apt-get update;sudo apt-get upgrade
- sudo apt-get install --reinstall rsyslog
The 'sudo systemctl status rsyslog.service' outputs the following:
● rsyslog.service - System Logging Service
   Loaded: loaded (/lib/systemd/system/rsyslog.service; enabled)
   Active: failed (Result: start-limit) since Wed 2018-03-07 07:57:54 EET; 32min ago
     Docs: man:rsyslogd(8)
           http://www.rsyslog.com/doc/
  Process: 568 ExecStart=/usr/sbin/rsyslogd -n (code=exited, status=127)
 Main PID: 568 (code=exited, status=127)
Mar 07 07:57:53 pi systemd[1]: Unit rsyslog.service entered failed state.
Mar 07 07:57:54 pi systemd[1]: rsyslog.service holdoff time over, scheduling restart.
Mar 07 07:57:54 pi systemd[1]: Stopping System Logging Service...
Mar 07 07:57:54 pi systemd[1]: Starting System Logging Service...
Mar 07 07:57:54 pi systemd[1]: rsyslog.service start request repeated too quickly, refusing to start.
Mar 07 07:57:54 pi systemd[1]: Failed to start System Logging Service.
Mar 07 07:57:54 pi systemd[1]: Unit rsyslog.service entered failed state.
I've also ran a strace on 'rsyslogd -n' and it seems that it fails to load some libraries:
$ strace rsyslogd -n
execve("/usr/sbin/rsyslogd", ["rsyslogd", "-n"], [/* 51 vars */]) = 0
brk(0)                                  = 0xd8e000
uname({sys="Linux", node="pi", ...}) = 0
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f9f000
access("/etc/ld.so.preload", R_OK)      = 0
open("/etc/ld.so.preload", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=42, ...}) = 0
mmap2(NULL, 42, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x76f9e000
close(3)                                = 0
open("/usr/lib/arm-linux-gnueabihf/libarmmem.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0h\5\0\0004\0\0\0"..., 512) = 512
lseek(3, 17960, SEEK_SET)               = 17960
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 960) = 960
lseek(3, 17696, SEEK_SET)               = 17696
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\3\f\1\22\4\24"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0644, st_size=18920, ...}) = 0
mmap2(NULL, 83236, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f5d000
mprotect(0x76f62000, 61440, PROT_NONE)  = 0
mmap2(0x76f71000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x76f71000
mprotect(0x7e98c000, 4096, PROT_READ|PROT_WRITE|PROT_EXEC|PROT_GROWSDOWN) = 0
close(3)                                = 0
munmap(0x76f9e000, 42)                  = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=83277, ...}) = 0
mmap2(NULL, 83277, PROT_READ, MAP_PRIVATE, 3, 0) = 0x76f48000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0l\30\0\0004\0\0\0"..., 512) = 512
lseek(3, 90768, SEEK_SET)               = 90768
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1120) = 1120
lseek(3, 90404, SEEK_SET)               = 90404
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0644, st_size=91888, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f9e000
mmap2(NULL, 155944, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f21000
mprotect(0x76f37000, 61440, PROT_NONE)  = 0
mmap2(0x76f46000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x76f46000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0lY\0\0004\0\0\0"..., 512) = 512
lseek(3, 120788, SEEK_SET)              = 120788
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1520) = 1520
lseek(3, 86420, SEEK_SET)               = 86420
read(3, "A0\0\0\0aeabi\0\1&\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\23\1\24"..., 49) = 49
fstat64(3, {st_mode=S_IFREG|0755, st_size=122308, ...}) = 0
mmap2(NULL, 160316, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76ef9000
mprotect(0x76f0d000, 65536, PROT_NONE)  = 0
mmap2(0x76f1d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x76f1d000
mmap2(0x76f1f000, 4668, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x76f1f000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\220\t\0\0004\0\0\0"..., 512) = 512
lseek(3, 8660, SEEK_SET)                = 8660
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1160) = 1160
lseek(3, 8328, SEEK_SET)                = 8328
fstat64(3, {st_mode=S_IFREG|0644, st_size=9820, ...}) = 0
mmap2(NULL, 73912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76ee6000
mprotect(0x76ee8000, 61440, PROT_NONE)  = 0
mmap2(0x76ef7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x76ef7000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0000\30\0\0004\0\0\0"..., 512) = 512
lseek(3, 25352, SEEK_SET)               = 25352
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1320) = 1320
lseek(3, 24964, SEEK_SET)               = 24964
fstat64(3, {st_mode=S_IFREG|0644, st_size=26672, ...}) = 0
mmap2(NULL, 90684, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76ecf000
mprotect(0x76ed5000, 61440, PROT_NONE)  = 0
mmap2(0x76ee4000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x76ee4000
close(3)                                = 0
open("/usr/lib/arm-linux-gnueabihf/libestr.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\274\t\0\0004\0\0\0"..., 512) = 512
lseek(3, 8556, SEEK_SET)                = 8556
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1000) = 1000
lseek(3, 8288, SEEK_SET)                = 8288
fstat64(3, {st_mode=S_IFREG|0644, st_size=9556, ...}) = 0
mmap2(NULL, 41060, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f93000
mprotect(0x76f95000, 28672, PROT_NONE)  = 0
mmap2(0x76f9c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x76f9c000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libuuid.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\4\17\0\0004\0\0\0"..., 512) = 512
lseek(3, 12836, SEEK_SET)               = 12836
lseek(3, 12528, SEEK_SET)               = 12528
fstat64(3, {st_mode=S_IFREG|0644, st_size=13996, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f92000
mmap2(NULL, 78080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76ebb000
mprotect(0x76ebe000, 61440, PROT_NONE)  = 0
mmap2(0x76ecd000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x76ecd000
close(3)                                = 0
open("/usr/lib/arm-linux-gnueabihf/liblogging-stdlog.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\30\t\0\0004\0\0\0"..., 512) = 512
lseek(3, 16808, SEEK_SET)               = 16808
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1040) = 1040
lseek(3, 16528, SEEK_SET)               = 16528
fstat64(3, {st_mode=S_IFREG|0644, st_size=17848, ...}) = 0
mmap2(NULL, 49312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76eae000
mprotect(0x76eb2000, 28672, PROT_NONE)  = 0
mmap2(0x76eb9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x76eb9000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libjson-c.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0008\"\0\0004\0\0\0"..., 512) = 512
lseek(3, 33612, SEEK_SET)               = 33612
lseek(3, 33276, SEEK_SET)               = 33276
fstat64(3, {st_mode=S_IFREG|0644, st_size=34652, ...}) = 0
mmap2(NULL, 66064, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76e9d000
mprotect(0x76ea5000, 28672, PROT_NONE)  = 0
mmap2(0x76eac000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x76eac000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0L\204\1\0004\0\0\0"..., 512) = 512
lseek(3, 1239936, SEEK_SET)             = 1239936
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 2840) = 2840
lseek(3, 1236500, SEEK_SET)             = 1236500
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\23\1\24"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=1242776, ...}) = 0
mmap2(NULL, 1312152, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76d5c000
mprotect(0x76e87000, 65536, PROT_NONE)  = 0
mmap2(0x76e97000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12b000) = 0x76e97000
mmap2(0x76e9a000, 9624, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x76e9a000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/v7l/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/v7l", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/tls/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/tls", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/v7l/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/v7l", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
open("/usr/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/v7l/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/v7l", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/tls/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/tls", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/v7l/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/v7l", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/arm-linux-gnueabihf/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/neon/vfp", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
open("/usr/lib/arm-linux-gnueabihf/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/neon", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
open("/usr/lib/arm-linux-gnueabihf/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf/vfp", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/arm-linux-gnueabihf/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=69632, ...}) = 0
open("/lib/tls/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/vfp", 0x7e98a510)  = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/lib/tls/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/tls/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/neon", 0x7e98a510)     = -1 ENOENT (No such file or directory)
open("/lib/tls/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/vfp", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/lib/tls/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls", 0x7e98a510)          = -1 ENOENT (No such file or directory)
open("/lib/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/lib/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/neon", 0x7e98a510)     = -1 ENOENT (No such file or directory)
open("/lib/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/vfp", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/lib/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l", 0x7e98a510)          = -1 ENOENT (No such file or directory)
open("/lib/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/neon/vfp", 0x7e98a510)     = -1 ENOENT (No such file or directory)
open("/lib/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/neon", 0x7e98a510)         = -1 ENOENT (No such file or directory)
open("/lib/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/vfp", 0x7e98a510)          = -1 ENOENT (No such file or directory)
open("/lib/raise", O_RDONLY|O_CLOEXEC)  = -1 ENOENT (No such file or directory)
stat64("/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/tls/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/v7l/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/v7l", 0x7e98a510)  = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/vfp", 0x7e98a510)  = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/usr/lib/v7l/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/v7l/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/v7l/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/v7l/neon", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/v7l/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/v7l/vfp", 0x7e98a510)  = -1 ENOENT (No such file or directory)
open("/usr/lib/v7l/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/v7l", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/usr/lib/neon/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/neon/vfp", 0x7e98a510) = -1 ENOENT (No such file or directory)
open("/usr/lib/neon/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/neon", 0x7e98a510)     = -1 ENOENT (No such file or directory)
open("/usr/lib/vfp/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/vfp", 0x7e98a510)      = -1 ENOENT (No such file or directory)
open("/usr/lib/raise", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
writev(2, [{"rsyslogd", 8}, {": ", 2}, {"error while loading shared libra"..., 36}, {": ", 2}, {"raise", 5}, {": ", 2}, {"cannot open shared object file", 30}, {": ", 2}, {"No such file or directory", 25}, {"\n", 1}], 10rsyslogd: error while loading shared libraries: raise: cannot open shared object file: No such file or directory
) = 113
exit_group(127)                         = ?
+++ exited with 127 +++
The RPi 3 was running fine for a few weeks and yesterday this problem occurred. Any help is much appreciated. If more info is needed I will provide it.
Thank you!
jostle
Re: Failed to start System Logging Service
Wed Mar 14, 2018 5:31 pm
I don't have a solution for you but on my Raspbian system there is no /etc/ld.so.nohwcap file nor any of the tls, v7l, neon files that are reported as missing in your strace output.
Have you installed any package that provides those files?
As far as syslogd goes, have a look in /etc/rsyslog.d to see if there are any config files that should not be there.
Have Fun ...
