calucio24
Hdmi no output on pi zero w
Thu Feb 01, 2018 11:09 pm
Hi guys, this is Carlo.
When I insert my sd card with the latest version of Raspbian (downloaded 28-01-18) on my pi 3 the hdmi output is ok, but when I insert the same sd card on my pi zero w I have not hdmi output.
Why this different behavior between pi 3 and pi zero w?
I have tried to change setting in config.txt, but nothing changed.
thanks
Carlo
B.Goode
Re: Hdmi no output on pi zero w
Fri Feb 02, 2018 7:35 am
Maybe the cable or adapter/convertor that you are using with the RPiZero is faulty?
calucio24
Fri Feb 02, 2018 7:39 am
The cable is the same on pi3 and pi zero w.
I'm desperate.
B.Goode
Fri Feb 02, 2018 8:09 am
The RPi3 has a standard full-size HDMI connection.
The RPiZeroW has a Mini HDMI connection.
calucio24
Fri Feb 02, 2018 8:15 am
Yes of course,
in my cable I can change the connector to switch between hdmi to mini hdmi.
I use this cable:
https://www.amazon.it/Chenyang-90-gradi ... i+90%C2%B0
B.Goode
Fri Feb 02, 2018 8:21 am
Have you tested that cable with some other source of a Mini HDMI signal?
Maybe it is faulty when used in its Mini HDMI mode?
fanoush
Fri Feb 02, 2018 8:30 am
so did you already increased config_hdmi_boost ?
check this viewtopic.php?f=28&t=198653
or this viewtopic.php?f=28&t=198748#p1241355
looks like pi zero hdmi is somewhat weaker or it is because of the additional mini-HDMI adapter
Paul Webster
Contact: Twitter
Fri Feb 02, 2018 10:14 am
Is your Pi0in a case?
If yes it is possible that the case is preventing the mini-HDMI connector going all of the way in.
I had that problem and resolved it by shaving some plastic from the end of the mini-HDMI connector.
calucio24
Fri Feb 02, 2018 10:20 am
Hi Paul, no is not in a case.
I'll try to set hdmi_boost=11 and let you know.
fanoush
Fri Feb 02, 2018 2:26 pm
for some reason it is actually config_hdmi_boost
unlike any other hdmi_xx parameter documented here https://www.raspberrypi.org/documentati ... t/video.md
carlodivita
Fri Feb 02, 2018 11:05 pm
Hi guys,
I set config_hdmi_boost=11 but nothing changed.
I have also tried to set hdmi_force_hotplug=1 with same result.
I have not other devices where I can test the cable with mini hdmi connector.
calucio24
Sun Feb 18, 2018 2:50 pm
Hi guys,
I’m using an fvp hdmi cable like this on raspberry pi zero w
https://www.amazon.it/dp/B0177ECP6S/ref ... IAb2X6FG9J
But in my monitor doesn’t appear
If I change mini hdmi side adapter with hdmi and use this with my raspberry 3 all works.
I return mini hdmi side adapter becouse I thought was broken. So i bought new mini hdmi side adapter but nothing changed.
Help me!! Please
Paul Webster
Contact: Twitter
Wed Feb 21, 2018 9:37 am
Have you tried the various suggestions from earlier in this thread?
calucio24
Wed Feb 21, 2018 9:47 am
Yes. I think that also this mini hdmi connector has a problem because with every different cable and connector all works good.
