PlanB
pixelmath
Thu Nov 23, 2017 10:30 am
I've been trying to get a python program for handling the seek thermal camera to run. By trial & error with apt-get install or pip install I've manged to wrestle most of the dependencies (pyusb1.0, pil, numpy, scipy, imagemagick, opencv, cv2, etc) into place on a Pi3 with Jessie. It's been a long tedious road since the original program is a couple of years old & maybe ran under wheezy?
Finally I'm stuck on 'ImportError: No module named pixelmath' which does not google a result. Since I've only got the vaguest idea of what I'm doing, once google doesn't return a result I'm stuffed. Any learned folk with a suggestion of what to try next?
B.Goode
Re: pixelmath
Thu Nov 23, 2017 10:37 am
It's not a particularly learned suggestion, but one possible approach would be to contact the original author/developer/maintainer of the code you are trying to re-implement for details of where that library module came from.
Using an internet search tool for the string "python pixelmath" does return a number of results that might be relevant.
