Georgi
Can't shutdown properly
Thu Nov 16, 2017 11:13 pm
Greetings!
Whenever i select shutdown from the menu or use "shutdown -P now" or "shutdown -H now" it gets to the blackscreen only showing "plymouth-poweroff.service" at the bottom left corner and stays there. It doesnt shutdown even after 10minutes. Restart works fine.
Its a RPI 3 B and raspberian.
christian02
Re: Can't shutdown properly
Fri Nov 17, 2017 9:43 pm
You should try typing
sudo shutdown h- now
pcmanbob
Fri Nov 17, 2017 11:18 pm
Actually it's sudo shutdown -h now
n67
Fri Nov 17, 2017 11:58 pm
Actually, it's:
init 0
or:
poweroff
"L'enfer, c'est les autres"
Epmu Sn!
HawaiianPi
Sat Nov 18, 2017 8:22 am
sudo shutdown -P now
and
Are pretty much the same thing. Either should work.
However, sudo shutdown -H now is an entirely different command (halt).
And sudo shutdown now (with no options) works fine for me.
Are you booting from USB or SD card?
