carriba
Contact: ICQ
Raspbian Jessie: Unable to connect to mirrordirector.raspbian.org
Fri Nov 10, 2017 4:55 pm
Seems that since this afternoon, I'm not abel to perform a Rapsbian Jessie update. I am m getting the following messages printed out:
The following packages will be upgraded:
  curl libavcodec56 libavformat56 libavresample2 libavutil54 libcurl3 libcurl3-gnutls libssl1.0.0 libswscale3 openssl wget
10 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,359 kB of archives.
After this operation, 331 kB of additional disk space will be used.
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavutil54 armhf 6:11.11-1~deb8u1+rpi1
  Unable to connect to mirrordirector.raspbian.org:http:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavresample2 armhf 6:11.11-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavcodec56 armhf 6:11.11-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavformat56 armhf 6:11.11-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main curl armhf 7.38.0-4+deb8u7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3 armhf 7.38.0-4+deb8u7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libswscale3 armhf 6:11.11-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main wget armhf 1.16-1+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main openssl armhf 1.0.1t-1+deb8u7
Fetched 955 kB in 2min 0s (7,940 B/s)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is the Raspbian Jessie repository still up and maintained?
HawaiianPi
Re: Raspbian Jessie: Unable to connect to mirrordirector.raspbian.org
Fri Nov 10, 2017 6:58 pm
Probably a temporary outage. It happens from time to time.
HawaiianPi
Fri Nov 10, 2017 8:14 pm
I flashed a Jessie card to check it out, and I too got an error on the raspbian repo, but I also noticed the response time and speed from the other repo was very slow. So I retried a few times and was eventually able to connect to both repos.
Then I tried an update on my Pi3 with Stretch and it also seemed slow (slower than usual, anyway). And curiously, Stretch was much slower on the raspberrypi.org repo. ¯\_(ツ)_/¯
So yea, something is going on with the repos today. Hopefully it'll get sorted soon.
carriba
Contact: ICQ
Sat Nov 11, 2017 1:00 pm
I've tried it again just right now, and still the same symptoms as I was observing yesterday. Hopefully, this gets resolved soon.
Pete_Stevens
Sat Nov 11, 2017 2:34 pm
It's not run by Mythic Beasts, but we have a login to the machine so I've increased the number of workers as it wasn't recycling connections quick enough.
tom3f
Sat Nov 11, 2017 4:00 pm
You can try change different mirror from this website
https://www.raspbian.org/RaspbianMirrors
