leelabks
Cannot Rotate the LCD display touch screen
Mon Aug 28, 2017 8:50 am
I am using the latest Raspian ("Linux raspberrypi 4.4.50-v7+") downloaded from raspberrypi.org, i can use the command "display_rotate=2" to rotate the screen display 180degC but i cannot rotate the capacitive touch display. After some study, i use "lcd_rotate=2", but i still cannot achieve to rotate the screen and the touch display.
i found some people are using xinput to rotate the touchscreen function, "viewtopic.php?f=108&t=120793". i have follow the instruction to install the xinput (sudo apt-get install xinput), but when i apply the following command,
DISPLAY=:0 xinput set-prop 'HID 19e2:2533' 'Evdev Axes Swap' 1
then the system reported,
property 'Evdev Axes Swap' doesn't exist, you need to specify its type and format.
i have run out of idea to rotate the capacitive touch screen, can anyone help to give some idea to rotate the capacitive touch screen?
DirkS
Re: Cannot Rotate the LCD display touch screen
Mon Aug 28, 2017 9:29 am
No, you're not:
Linux raspi07 4.9.41+ #1023 Tue Aug 8 15:47:12 BST 2017 armv6l GNU/Linux
Are you using the Official RPF screen?
If you do then using that usb ID will probably not work...
leelabks
Tue Aug 29, 2017 7:39 am
i am not using the original Raspberry Pi 7 inch LCD panel, this LCD panel is from another brand. However, i am able to use the capacitive touch panel without rotating the screen. The problem is i cannot rotate the touch panel. In the earlier post, you mentioned that the USB ID will probably not work, can you explain more on this and what i should do to make it work? Thanks.
DirkS
Tue Aug 29, 2017 7:07 pm
I said that if you were using the RPF screen using the USB would not work.
That's because the RPF screen doesn't use USB...
You probably need to create / configure the X11 touch calibration file.
No idea what to put in there to make it work for you, though.
texy
Wed Aug 30, 2017 6:47 am
..posted in the wrong sub-forum, so moving to Troubleshooting.
Texy
