bytesnz
Pi 3 internal WiFi adaptor stopping when used as AP
Mon Jul 24, 2017 7:30 am
Hello all,
I have set up a Raspberry Pi 3 Model B as a wireless access point using the internal WiFi adaptor and hostapd, but the AP keeps on stopping after about 5-10 minutes (AP disappears, but Pi is still working). There are quite a few devices connected to it (5-10), but I would have thought it would be able to handle it. Below is the hostapd configuration and the error messages from the kern.log.
The Pi is running NOOBs with the lastest updates installed (Debian 8.0). Before updating to the latest kernel, I was also getting stack trace errors in kern.log, which I have also included below (just in case). When I try and restart hostapd after the AP disappears, the AP flashes up, but disappears again and produces error messages, which I have included right at the bottom.
Any help would be greatly appreciated.
/etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=RD
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=password
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wmm_enabled=1
ht_capab=[HT40][SHORT-GI-20][DSS_CCK-40]
Below are the error messages in /var/log/kern.log after the AP goes down
/var/log/kern.log
Jul 24 06:59:37 rd kernel: [  859.650243] brcmfmac: brcmf_sdio_hostmail: Unknown mailbox data content: 0x40012
Jul 24 06:59:49 rd kernel: [  871.604925] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 06:59:52 rd kernel: [  874.164872] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 06:59:52 rd kernel: [  874.164885] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
Jul 24 07:00:04 rd kernel: [  886.724881] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:07 rd kernel: [  889.284896] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:07 rd kernel: [  889.284908] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
Jul 24 07:00:18 rd kernel: [  900.804890] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:21 rd kernel: [  903.364904] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:21 rd kernel: [  903.364917] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
Jul 24 07:00:48 rd kernel: [  930.804940] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:51 rd kernel: [  933.364929] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:00:51 rd kernel: [  933.364941] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
Jul 24 07:02:03 rd kernel: [ 1004.965011] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:02:05 rd kernel: [ 1007.525069] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:02:05 rd kernel: [ 1007.525082] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
Jul 24 07:05:40 rd kernel: [ 1222.021038] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:05:42 rd kernel: [ 1224.581211] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:05:45 rd kernel: [ 1227.141435] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:05:47 rd kernel: [ 1229.701593] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:05:50 rd kernel: [ 1232.261802] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:05:52 rd kernel: [ 1234.821993] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:05:55 rd kernel: [ 1237.382182] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:05:58 rd kernel: [ 1239.942370] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:06:00 rd kernel: [ 1242.502553] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:06:03 rd kernel: [ 1245.062745] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:06:05 rd kernel: [ 1247.622927] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:06:08 rd kernel: [ 1250.183149] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:06:09 rd kernel: [ 1251.143206] brcmfmac: brcmf_netdev_wait_pend8021x: Timed out waiting for no pending 802.1x packets
Jul 24 07:06:11 rd kernel: [ 1253.703368] brcmfmac: send_key_to_dongle: wsec_key error (-110)
Jul 24 07:06:14 rd kernel: [ 1256.263581] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:06:16 rd kernel: [ 1258.823778] brcmfmac: brcmf_cfg80211_change_station: Setting SCB (de-)authorize failed, -110
Jul 24 07:06:19 rd kernel: [ 1261.383960] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Prior to upgrade stack trace
Jul 24 06:23:47 rd kernel: [  656.708719] brcmfmac: send_key_to_dongle: wsec_key error (-52)
Jul 24 06:23:49 rd kernel: [  658.708705] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -52
Jul 24 06:23:51 rd kernel: [  660.708704] brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -52
Jul 24 06:23:51 rd kernel: [  660.758695] ------------[ cut here ]------------
Jul 24 06:23:51 rd kernel: [  660.758780] WARNING: CPU: 3 PID: 669 at drivers/net/wireless/brcm80211/brcmfmac/core.c:1191 brcmf_netdev_wait_pend8021x+0xe4/0xf0 [brcmfmac]()
Jul 24 06:23:51 rd kernel: [  660.758790] Modules linked in: bnep hci_uart btbcm nfnetlink_queue nfnetlink_log nfnetlink bluetooth ip6table_filter ip6_tables xt_conntrack iptable_filter ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_nat xt_tcpudp iptable_nat nf_conntrack_ipv4
 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables x_tables brcmfmac brcmutil cfg80211 rfkill snd_bcm2835 snd_pcm snd_timer snd bcm2835_wdt bcm2835_gpiomem uio_pdrv_genirq uio i2c_dev fuse ipv6
Jul 24 06:23:51 rd kernel: [  660.758953] CPU: 3 PID: 669 Comm: hostapd Tainted: G        W       4.4.50-v7+ #970
Jul 24 06:23:51 rd kernel: [  660.758963] Hardware name: BCM2709
Jul 24 06:23:51 rd kernel: [  660.758999] [<800187c0>] (unwind_backtrace) from [<80014094>] (show_stack+0x20/0x24)
Jul 24 06:23:51 rd kernel: [  660.759023] [<80014094>] (show_stack) from [<80321ce4>] (dump_stack+0xd4/0x118)
Jul 24 06:23:51 rd kernel: [  660.759047] [<80321ce4>] (dump_stack) from [<8002541c>] (warn_slowpath_common+0x98/0xc8)
Jul 24 06:23:51 rd kernel: [  660.759071] [<8002541c>] (warn_slowpath_common) from [<80025508>] (warn_slowpath_null+0x2c/0x34)
Jul 24 06:23:51 rd kernel: [  660.759139] [<80025508>] (warn_slowpath_null) from [<7f25d1e0>] (brcmf_netdev_wait_pend8021x+0xe4/0xf0 [brcmfmac])
Jul 24 06:23:51 rd kernel: [  660.759255] [<7f25d1e0>] (brcmf_netdev_wait_pend8021x [brcmfmac]) from [<7f24bfbc>] (send_key_to_dongle+0xa4/0xf8 [brcmfmac])
Jul 24 06:23:51 rd kernel: [  660.759368] [<7f24bfbc>] (send_key_to_dongle [brcmfmac]) from [<7f24c208>] (brcmf_cfg80211_del_key+0x68/0x78 [brcmfmac])
Jul 24 06:23:51 rd kernel: [  660.759513] [<7f24c208>] (brcmf_cfg80211_del_key [brcmfmac]) from [<7f1974a8>] (nl80211_del_key+0xfc/0x28c [cfg80211])
Jul 24 06:23:51 rd kernel: [  660.759604] [<7f1974a8>] (nl80211_del_key [cfg80211]) from [<80509260>] (genl_rcv_msg+0x26c/0x3f0)
Jul 24 06:23:51 rd kernel: [  660.759625] [<80509260>] (genl_rcv_msg) from [<80508438>] (netlink_rcv_skb+0xb0/0xcc)
Jul 24 06:23:51 rd kernel: [  660.759642] [<80508438>] (netlink_rcv_skb) from [<80508fe4>] (genl_rcv+0x34/0x44)
Jul 24 06:23:51 rd kernel: [  660.759659] [<80508fe4>] (genl_rcv) from [<80507d74>] (netlink_unicast+0x194/0x258)
Jul 24 06:23:51 rd kernel: [  660.759676] [<80507d74>] (netlink_unicast) from [<80508240>] (netlink_sendmsg+0x340/0x354)
Jul 24 06:23:51 rd kernel: [  660.759697] [<80508240>] (netlink_sendmsg) from [<804ba988>] (sock_sendmsg+0x24/0x34)
Jul 24 06:23:51 rd kernel: [  660.759719] [<804ba988>] (sock_sendmsg) from [<804bb070>] (___sys_sendmsg+0x1e0/0x1e8)
Jul 24 06:23:51 rd kernel: [  660.759741] [<804bb070>] (___sys_sendmsg) from [<804bbdc8>] (__sys_sendmsg+0x4c/0x7c)
Jul 24 06:23:51 rd kernel: [  660.759763] [<804bbdc8>] (__sys_sendmsg) from [<804bbe10>] (SyS_sendmsg+0x18/0x1c)
Jul 24 06:23:51 rd kernel: [  660.759784] [<804bbe10>] (SyS_sendmsg) from [<8000fb60>] (ret_fast_syscall+0x0/0x1c)
Jul 24 06:23:51 rd kernel: [  660.759796] ---[ end trace 0e34cb65afabe318 ]---
Errors after restarting hostapd after AP goes down
Jul 24 07:23:43 rd kernel: brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Jul 24 07:23:49 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: SET SSID error (-110)
Jul 24 07:23:51 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: BRCMF_C_DOWN error -110
Jul 24 07:23:54 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -110
Jul 24 07:23:56 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: setting AP mode failed -110
Jul 24 07:24:02 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: BRCMF_C_UP error -110
Jul 24 07:24:04 rd kernel: brcmfmac: brcmf_set_mpc: fail to set mpc
Jul 24 07:24:15 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: SET SSID error (-110)
Jul 24 07:24:17 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: BRCMF_C_DOWN error -110
Jul 24 07:24:20 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -110
Jul 24 07:24:22 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: setting AP mode failed -110
Jul 24 07:24:28 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: BRCMF_C_UP error -110
Jul 24 07:24:30 rd kernel: brcmfmac: brcmf_set_mpc: fail to set mpc
Jul 24 07:24:38 rd kernel: brcmfmac: brcmf_cfg80211_change_iface: WLC_SET_INFRA error (-110)
Jul 24 07:24:40 rd kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:24:40 rd kernel: brcmfmac: brcmf_cfg80211_get_channel: chanspec failed (-110)
Jul 24 07:24:43 rd kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:24:43 rd kernel: brcmfmac: brcmf_cfg80211_get_tx_power: error (-110)
Jul 24 07:24:46 rd kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:24:46 rd kernel: brcmfmac: brcmf_cfg80211_get_channel: chanspec failed (-110)
Jul 24 07:24:48 rd kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:24:48 rd kernel: brcmfmac: brcmf_cfg80211_get_tx_power: error (-110)
Jul 24 07:24:51 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting mcast_list failed, -110
Jul 24 07:24:53 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting allmulti failed, -110
Jul 24 07:24:56 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting BRCMF_C_SET_PROMISC failed, -110
Jul 24 07:25:01 rd kernel: brcmfmac: brcmf_cfg80211_stop_ap: SET SSID error (-110)
Jul 24 07:25:55 rd kernel: brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 24 07:25:55 rd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jul 24 07:25:58 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting mcast_list failed, -110
Jul 24 07:26:00 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting allmulti failed, -110
Jul 24 07:26:03 rd kernel: brcmfmac: _brcmf_set_multicast_list: Setting BRCMF_C_SET_PROMISC failed, -110
Re: Pi 3 internal WiFi adaptor stopping when used as AP
Mon Jul 24, 2017 8:28 am
Just to confirm, can you post the output of uname -a so we can be sure which kernel you have. There have been a couple of Wifi fixes in the last 3 months which may help so will be interesting to see if you have them.
That mailbox issue is currently under investigation, although I have been unable to replicate it. Might be worth posting your error report on the Wifi github issue. https://github.com/raspberrypi/linux/issues/1342
Are there any Samsung devices attaching? Anecdotally, some SS kit seems to cause issues.
bytesnz
Mon Jul 24, 2017 8:33 am
Hi jamesh,
Thanks for your reply. Ah yes, that it always helpful
Linux rd 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
Yes. There are a couple of Samsung phones connecting to it.
I have just added ieee80211n=1 to the hostapd config and it seems to be stable at the moment running in a console in debug mode. My updated hostapd config below. Just going to wait until lunchtime (when there will be lots of people trying to connect to the network) to see if it crashes again.
Will have a look at the github issue. If there are any other outputs you would find helpful for the wlan bug, feel free to give them to me and I will rebreak it.
interface=wlan0
#driver=nl80211
ssid=RD
hw_mode=g
channel=1
macaddr_acl=0
auth_algs=1
ieee80211n=1
wpa=3
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wmm_enabled=1
bytesnz
Wed Jul 26, 2017 6:10 am
Had one day of perfection, but it keeps stopping now. Logs/Output below. Let me know if there is any debug logs tool I can run to get you more info.
Update: Changing the encryption to
wpa=2
seems to have stopped the issue from occurring at the moment.
journalctl:
Jul 26 09:00:19 rd kernel: [  292.510915] brcmfmac: brcmf_sdio_hostmail: Unknown mailbox data content: 0x40012
/var/log/kern.log:
Jul 26 09:04:17 rd kernel: [  530.966128] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 26 09:04:20 rd kernel: [  533.526073] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Jul 26 09:04:20 rd kernel: [  533.526085] brcmfmac: brcmf_cfg80211_get_station: GET STA INFO failed, -110
hostapd -d:
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd/hostapd.conf
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
rfkill: initial event: idx=1 type=2 op=0 soft=0 hard=0
nl80211: TDLS supported
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Using driver-based off-channel TX
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=1
nl80211: Create interface iftype 6 (MONITOR)
Failed to create interface mon.wlan0: -95 (Operation not supported)
nl80211: Driver does not support monitor interface type - try to run without it
nl80211: Enable Probe Request reporting nl_preq=0x56015fe8
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x56015fe8 match=
nl80211: Register frame command failed (type=64): ret=-22 (Invalid argument)
nl80211: Register frame match - hexdump(len=0): [NULL]
nl80211: Failed to enable Probe Request frame reporting in AP mode
nl80211: Add own interface ifindex 3
nl80211: if_indices[16]: 3
nl80211: Do not indicate P2P_DEVICE support (p2p_device=1 driver param not specified)
phy: phy0
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
hw vht capab: 0x0, conf vht capab: 0x0
Completing interface initialization
Mode: IEEE 802.11g  Channel: 1  Frequency: 2412 MHz
DFS 0 channels required radar detection
nl80211: Set freq 2412 (ht_enabled=1, vht_enabled=0, bandwidth=20 MHz, cf1=2412 MHz, cf2=0 MHz)
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
hostapd_setup_bss(hapd=0x56016620 (wlan0), first=1)
wlan0: Flushing old station entries
nl80211: flush -> DEL_STATION wlan0 (all)
nl80211: Station flush failed: ret=-14 (Bad address)
wlan0: Could not connect to kernel driver
wlan0: Deauthenticate all stations
nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
nl80211: set_key failed; err=-22 Invalid argument)
Failed to clear default encryption keys (ifname=wlan0 keyidx=0)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
Failed to clear default encryption keys (ifname=wlan0 keyidx=1)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
Failed to clear default encryption keys (ifname=wlan0 keyidx=2)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Failed to clear default encryption keys (ifname=wlan0 keyidx=3)
Using interface wlan0 with hwaddr b8:27:eb:d6:b2:52 and ssid "RD"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=2):
     52 44                                             RD
PSK (ASCII passphrase) - hexdump_ascii(len=14): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
random: Got 15/20 bytes from /dev/random
random: Only 15/20 bytes of strong random data available from /dev/random
random: Not enough entropy pool available for secure operations
WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=53): 80 00 00 00 ff ff ff ff ff ff b8 27 eb d6 b2 52 b8 27 eb d6 b2 52 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 02 52 44 01 08 82 84 8b 96 0c 12 18 24 03 01 01
nl80211: Beacon tail - hexdump(len=139): 2a 01 04 32 04 30 48 60 6c 30 14 01 00 00 0f ac 02 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 2d 1a 2c 00 1f ff 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 04 00 00 00 02 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=3
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=2):
     52 44                                             RD
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x3
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x18
nl80211: group_cipher=0x8
nl80211: beacon_ies - hexdump(len=6): 7f 04 00 00 00 02
nl80211: proberesp_ies - hexdump(len=6): 7f 04 00 00 00 02
nl80211: assocresp_ies - hexdump(len=6): 7f 04 00 00 00 02
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
GTK - hexdump(len=32): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=2 addr=0x54c4d358 key_idx=1 set_tx=1 seq_len=0 key_len=32
nl80211: KEY_DATA - hexdump(len=32): [REMOVED]
   broadcast key
nl80211: Set wlan0 operstate 0->1 (UP)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
Failed to set TX queue parameters for queue 0.
Failed to set TX queue parameters for queue 1.
Failed to set TX queue parameters for queue 2.
Failed to set TX queue parameters for queue 3.
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
wlan0: Setup of interface done.
ctrl_iface not configured!
random: Got 5/5 bytes from /dev/random
RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
VLAN: vlan_newlink(wlan0)
nl80211: Drv Event 19 (NL80211_CMD_NEW_STATION) received for wlan0
nl80211: New station 64:27:37:e3:26:f7
nl80211: Assoc Req IEs - hexdump(len=84): 00 02 52 44 01 08 82 84 8b 96 24 30 48 6c 21 02 0b 13 24 02 01 0e 32 04 0c 12 18 60 7f 08 01 00 00 00 00 00 00 40 dd 09 00 10 18 02 00 00 00 00 00 dd 07 00 50 f2 02 00 01 00 dd 18 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 08 00
wlan0: Event ASSOC (0) received
wlan0: STA 64:27:37:e3:26:f7 IEEE 802.11: associated
STA included WPA IE in (Re)AssocReq
  New STA
ap_sta_add: register ap_handle_timer timeout for 64:27:37:e3:26:f7 (300 seconds - ap_max_inactivity)
nl80211: Set STA flags - ifname=wlan0 addr=64:27:37:e3:26:f7 total_flags=0x0 flags_or=0x0 flags_and=0xfffffff1 authorized=0
wlan0: STA 64:27:37:e3:26:f7 WPA: event 1 notification
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=0x5601be20 key_idx=0 set_tx=1 seq_len=0 key_len=0
IEEE 802.1X: Ignore STA - 802.1X not enabled or forced for WPS
wlan0: STA 64:27:37:e3:26:f7 WPA: start authentication
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state INITIALIZE
nl80211: Set STA flags - ifname=wlan0 addr=64:27:37:e3:26:f7 total_flags=0x0 flags_or=0x0 flags_and=0xfffffffe authorized=0
wlan0: STA 64:27:37:e3:26:f7 IEEE 802.1X: unauthorizing port
WPA: 64:27:37:e3:26:f7 WPA_PTK_GROUP entering state IDLE
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state AUTHENTICATION
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state AUTHENTICATION2
WPA: Re-initialize GMK/Counter on first station
   broadcast key
WPA: Assign ANonce - hexdump(len=32): 4b 1d 13 70 d6 2a ad ad 7c a4 e5 c9 d0 b5 3c ea 61 c2 64 dd 82 b1 38 5f 66 49 5b 36 de 3a ed d1
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state INITPSK
Searching a PSK for 64:27:37:e3:26:f7 prev_psk=(nil)
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state PTKSTART
wlan0: STA 64:27:37:e3:26:f7 WPA: sending 1/4 msg of 4-Way Handshake
WPA: Send EAPOL(version=1 secure=0 mic=0 ack=1 install=0 pairwise=1 kde_len=0 keyidx=0 encr=0)
WPA: Use EAPOL-Key timeout of 100 ms (retry counter 1)
hostapd_new_assoc_sta: reschedule ap_handle_timer timeout for 64:27:37:e3:26:f7 (300 seconds - ap_max_inactivity)
wlan0: Event EAPOL_RX (26) received
IEEE 802.1X: 125 bytes from 64:27:37:e3:26:f7
   IEEE 802.1X: version=1 type=3 length=121
WPA: Received EAPOL-Key from 64:27:37:e3:26:f7 key_info=0x109 type=254 key_data_length=26
WPA: Received Key Nonce - hexdump(len=32): 22 a7 09 d6 35 82 6a 28 ad 69 4b c6 64 7f e3 e3 a7 17 c9 26 ab 5e 4e 9c 36 fb 0d ce f6 3f ed eb
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 01
wlan0: STA 64:27:37:e3:26:f7 WPA: received EAPOL-Key frame (2/4 Pairwise)
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state PTKCALCNEGOTIATING
WPA: PTK derivation - A1=b8:27:eb:d6:b2:52 A2=64:27:37:e3:26:f7
WPA: Nonce1 - hexdump(len=32): 4b 1d 13 70 d6 2a ad ad 7c a4 e5 c9 d0 b5 3c ea 61 c2 64 dd 82 b1 38 5f 66 49 5b 36 de 3a ed d1
WPA: Nonce2 - hexdump(len=32): 22 a7 09 d6 35 82 6a 28 ad 69 4b c6 64 7f e3 e3 a7 17 c9 26 ab 5e 4e 9c 36 fb 0d ce f6 3f ed eb
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=64): [REMOVED]
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state PTKCALCNEGOTIATING2
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state PTKINITNEGOTIATING
wlan0: STA 64:27:37:e3:26:f7 WPA: sending 3/4 msg of 4-Way Handshake
WPA: Send EAPOL(version=1 secure=0 mic=1 ack=1 install=1 pairwise=1 kde_len=24 keyidx=0 encr=0)
IEEE 802.1X: 99 bytes from 64:27:37:e3:26:f7
   IEEE 802.1X: version=1 type=3 length=95
WPA: Received EAPOL-Key from 64:27:37:e3:26:f7 key_info=0x109 type=254 key_data_length=0
WPA: Received Key Nonce - hexdump(len=32): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 02
wlan0: STA 64:27:37:e3:26:f7 WPA: received EAPOL-Key frame (4/4 Pairwise)
WPA: 64:27:37:e3:26:f7 WPA_PTK entering state PTKINITDONE
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=2 addr=0x5601be20 key_idx=0 set_tx=1 seq_len=0 key_len=32
wlan0: AP-STA-CONNECTED 64:27:37:e3:26:f7
nl80211: Set STA flags - ifname=wlan0 addr=64:27:37:e3:26:f7 total_flags=0x1 flags_or=0x1 flags_and=0xffffffff authorized=1
wlan0: STA 64:27:37:e3:26:f7 IEEE 802.1X: authorizing port
wlan0: STA 64:27:37:e3:26:f7 RADIUS: starting accounting session 59782F18-00000000
wlan0: STA 64:27:37:e3:26:f7 WPA: pairwise key handshake completed (WPA)
WPA: 64:27:37:e3:26:f7 WPA_PTK_GROUP entering state REKEYNEGOTIATING
wlan0: STA 64:27:37:e3:26:f7 WPA: sending 1/2 msg of Group Key Handshake
WPA: Send EAPOL(version=1 secure=1 mic=1 ack=1 install=0 pairwise=0 kde_len=32 keyidx=1 encr=1)
Plaintext EAPOL-Key Key Data - hexdump(len=32): [REMOVED]
WPA: Use EAPOL-Key timeout of 500 ms (retry counter 1)
WPA: Received EAPOL-Key from 64:27:37:e3:26:f7 key_info=0x301 type=254 key_data_length=0
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 03
wlan0: STA 64:27:37:e3:26:f7 WPA: received EAPOL-Key frame (2/2 Group)
WPA: 64:27:37:e3:26:f7 WPA_PTK_GROUP entering state REKEYESTABLISHED
wlan0: STA 64:27:37:e3:26:f7 WPA: group key handshake completed (WPA)
nl80211: New station 60:57:18:cd:ee:c0
nl80211: Assoc Req IEs - hexdump(len=95): 00 02 52 44 01 08 02 04 0b 16 0c 12 18 24 32 04 30 48 60 6c 21 02 00 16 24 1a 01 01 02 01 03 01 04 01 05 01 06 01 07 01 08 01 09 01 0a 01 0b 01 0c 01 0d 01 7f 08 04 00 0a 02 00 00 00 40 dd 07 00 50 f2 02 00 01 00 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
wlan0: STA 60:57:18:cd:ee:c0 IEEE 802.11: associated
  New STA
ap_sta_add: register ap_handle_timer timeout for 60:57:18:cd:ee:c0 (300 seconds - ap_max_inactivity)
nl80211: Set STA flags - ifname=wlan0 addr=60:57:18:cd:ee:c0 total_flags=0x0 flags_or=0x0 flags_and=0xfffffff1 authorized=0
wlan0: STA 60:57:18:cd:ee:c0 WPA: event 1 notification
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=0x5601c6a0 key_idx=0 set_tx=1 seq_len=0 key_len=0
wlan0: STA 60:57:18:cd:ee:c0 WPA: start authentication
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state INITIALIZE
nl80211: Set STA flags - ifname=wlan0 addr=60:57:18:cd:ee:c0 total_flags=0x0 flags_or=0x0 flags_and=0xfffffffe authorized=0
wlan0: STA 60:57:18:cd:ee:c0 IEEE 802.1X: unauthorizing port
WPA: 60:57:18:cd:ee:c0 WPA_PTK_GROUP entering state IDLE
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state AUTHENTICATION
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state AUTHENTICATION2
WPA: Assign ANonce - hexdump(len=32): 94 ab 17 c2 20 a2 ce d4 55 02 9d 66 f5 3e 6c 54 78 dd e6 61 da 23 bb b8 56 e4 34 30 cf ad fb 4a
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state INITPSK
Searching a PSK for 60:57:18:cd:ee:c0 prev_psk=(nil)
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state PTKSTART
wlan0: STA 60:57:18:cd:ee:c0 WPA: sending 1/4 msg of 4-Way Handshake
hostapd_new_assoc_sta: reschedule ap_handle_timer timeout for 60:57:18:cd:ee:c0 (300 seconds - ap_max_inactivity)
wlan0: STA 60:57:18:cd:ee:c0 WPA: EAPOL-Key timeout
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 2)
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 3)
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 4)
wlan0: STA 60:57:18:cd:ee:c0 WPA: PTKSTART: Retry limit 4 reached
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state DISCONNECT
wpa_sta_disconnect STA 60:57:18:cd:ee:c0
hostapd_wpa_auth_disconnect: WPA authenticator requests disconnect: STA 60:57:18:cd:ee:c0 reason 2
nl80211: sta_remove -> DEL_STATION wlan0 60:57:18:cd:ee:c0 --> 0 (Success)
wlan0: STA 60:57:18:cd:ee:c0 WPA: event 3 notification
WPA: wpa_sm_step() called recursively
ap_sta_disconnect: reschedule ap_handle_timer timeout for 60:57:18:cd:ee:c0 (5 seconds - AP_MAX_INACTIVITY_AFTER_DEAUTH)
WPA: 60:57:18:cd:ee:c0 WPA_PTK entering state DISCONNECTED
nl80211: Drv Event 20 (NL80211_CMD_DEL_STATION) received for wlan0
nl80211: Delete station 60:57:18:cd:ee:c0
wlan0: Event DISASSOC (1) received
wlan0: STA 60:57:18:cd:ee:c0 IEEE 802.11: disassociated
wlan0: STA 60:57:18:cd:ee:c0 WPA: event 2 notification
hostapd_ht_operation_update current operation mode=0x0
hostapd_ht_operation_update new operation mode=0x0 changes=0
ap_free_sta: cancel ap_handle_timer for 60:57:18:cd:ee:c0
ap_handle_timer: 64:27:37:e3:26:f7 flags=0x23 timeout_next=0
wlan0: Check inactivity: Could not get station info from kernel driver for 64:27:37:e3:26:f7
ap_handle_timer: register ap_handle_timer timeout for 64:27:37:e3:26:f7 (305 seconds)
wlan0: WPA rekeying GTK
WPA: group state machine entering state SETKEYS (VLAN-ID 0)
WPA: Send EAPOL(version=1 secure=1 mic=1 ack=1 install=0 pairwise=0 kde_len=32 keyidx=2 encr=1)
wpa_group_setkeys: GKeyDoneStations=1
wlan0: STA 64:27:37:e3:26:f7 WPA: EAPOL-Key timeout
Output of hostapd after it is stopped and started again:
nl80211: Enable Probe Request reporting nl_preq=0x557fafe8
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x557fafe8 match=
phy: phy0
nl80211: Failed to set channel (freq=2412): -16 (Device or resource busy)
Could not set channel for kernel driver
Interface initialization failed
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
wlan0: Unable to setup interface.
hostapd_interface_deinit_free(0x557fa9f0)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x557fa9f0)
hostapd_bss_deinit: deinit bss wlan0
nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> -110 (Connection timed out)
hostapd_cleanup(hapd=0x557fb620 (wlan0))
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=0x54c80494 drv_priv=0x557fbed8 -> hapd_deinit
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=3)
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
hostapd_interface_free(0x557fa9f0)
hostapd_interface_free: free hapd 0x557fb620
hostapd_cleanup_iface(0x557fa9f0)
hostapd_cleanup_iface_partial(0x557fa9f0)
hostapd_cleanup_iface: free iface=0x557fa9f0
mnemonic
Fri Jul 28, 2017 3:33 pm
I got tired of trying to make WLAN0 work as an AP, after a long lost time I decided to buy a TP-Link WN722N and use it. Problem solved, I never had any problems.
But I keep thinking, the Broadcom drivers are bugged or the problem is in the hardware?
bytesnz
Tue Aug 08, 2017 1:51 pm
Just an update. The AP point that I have set up has been working solidly for the past couple of weeks using the following configuration.
interface=wlan0
driver=nl80211
ssid=RD
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
wpa=2
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wmm_enabled=1
The last change (changing wpa=3 to wpa=2) seems to have fixed the issue, so I wonder if the issue is something to do with WPA?
