windows cannot access raspberrypi
Posted: Mon Jul 17, 2017 1:29 pm
by pxf.hit
as shown in this figure. I am using Win10 to access raspberry failed. cannot access.
My pi's IP is 192.168.2.104. So I tried to use the IP address to access it.
But it's failed again.
I also try to ping the IP, and it works.
So, my issue is that, I can find the Raspberry share folder on the network, but cannot access it.
Some one please help me, thanks.
Re: windows cannot access raspberrypi
Posted: Mon Jul 17, 2017 6:16 pm
by drgeoff
pxf.hit wrote: So, my issue is that, I can find the Raspberry share folder on the network, but cannot access it.
What is your evidence for "I can find the Raspberry share folder on the network"? Being able to ping the RPi is not it.
I suspect that samba server is not running on your RPi. Is it even installed?
Posted: Tue Jul 18, 2017 6:58 am
by pxf.hit
Thanks for your reply.
Use the windows network to view the shared computers in LAN.
And I have installed the samba.
Posted: Tue Jul 18, 2017 8:25 am
by LetHopeItsSnowing
Is windows firewall restricting access?
Posted: Tue Jul 18, 2017 8:50 am
by mattmiller
How did you install samba
What is your smb.conf file
I use this one
#======================= Global Settings =======================
[global]
workgroup = WORKGROUP
wide links = yes
unix extensions = no
dns proxy = no
#### Debugging/Accounting ####
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
security = user
map to guest = Bad User
guest account = pi
#======================= Share Definitions =======================
[root]
comment = Admin Config Share
path = /
browseable = yes
force user = root
force group = root
admin users = pi
writeable = yes
read only = no
guest ok = yes
create mask = 0777
directory mask = 0777
[pi]
comment = pi user /homepi folder
path = /home/pi
browseable = yes
force user = pi
force group = pi
admin users = pi
writeable = yes
read only = no
guest ok = yes
create mask = 0777
Posted: Tue Jul 18, 2017 1:17 pm
by drgeoff
Is the samba server running?
Posted: Mon Sep 11, 2017 2:24 am
by pxf.hit
Thank you all for your kind reply.
I have solve the issue of access. The problem is from the user credentials. Cause the first time I use the option of remenbering password.
After I clear the Windows Credentials. It's ok to access the samba.
