otyugh
[solved]Certbot (LETSENCRYPT) - Illegal instruction
Tue Jun 27, 2017 9:23 am
Hey,
I couldn't succeed using certbot on raspbian jessie. I tried both installing it (and its dependency) from raspbian testing (deb http://mirrordirector.raspbian.org/raspbian/ testing main) and from debian arm jessie-backports (deb http://ftp.fr.debian.org/debian/ jessie-backports main).
All my tries resulted in an error-less installation, but certbot itself issues a "Illegal instruction" wathever the argument givent (or even with no argument at all).
I saw there were many problem around this, but I couldn't find any correct answer around it yet. It is, lot of people think, bind to the RPi architecture armv6 when debian arm uses armv7 ? - this would explains the fail for je jessie-backport. What about the raspbian testing issue, then ?
My actual testing ground is a RPi rev1B. I'm up to try stuffs if you have clues !
RaTTuS
Re: Certbot (LETSENCRYPT) -
Tue Jun 27, 2017 10:51 am
you =will probably have to build it from source
Covfefe
Tue Jun 27, 2017 11:12 am
otyugh wrote:Hey,
You are correct that Debian Jessie ARMHF Hard Float is for ARMv7 instruction set, so totally an excercise in fruitality trying to use those packages !
Debian ARMEL supports ARMv4/5/6 Soft Float instruction set which was the original Operating System offered for the Raspberry Pi's.
So the way forward is to build from Source
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
Tue Jun 27, 2017 11:24 am
fruitoftheloom wrote: an excercise in fruitality
I see what you did there....
otyugh
Tue Jun 27, 2017 2:38 pm
Quite a loss of time there, fault of remaining backported packages : after struggling at "de-backport" my system (for others that do the same mistake : dpkg-query -W | grep ~bpo + apt-cache policy to know what version to downgrade + apt-get install package=version).
I then upgraded to realize some package where backported in the native raspbian jessie repo already (this is not very... inutitive).
Well, and then, installing certbot from raspbian stretch - worked.
Fieel
Re: [solved]Certbot (LETSENCRYPT) - Illegal instruction
Sun Apr 07, 2019 3:10 pm
Yup, updating the source.list and upgrading did the trick
