karvalho
Rasp2 running on USB Stick, kernel upgrade problem
Wed Jun 21, 2017 1:02 pm
I managed to boot a raspberry pi 2 from a usb stick, using the root parameter on /boot/cmdline.txt in my sd card, and having raspbian copied to my usb drive.
Everything's fine, till I
apt-get update && apt-get upgrade
Before upgrade, uname -r returns:
4.4.50-v7+
In the upgrade it's included the package raspberrypi-kernel, a newer kernel, perhaps?
But after upgrading and rebooting, I have a "Failed to start Load Kernel Modules", uname -r still shows 4.4.50-v7+, and depmod returns
"ERROR: could not open directory /lib/modules/4.4.50-v7+"
I presume the kernel is upgraded on my usb stick, but not on the /boot partition, the reason why these references are broken?
Did I do something wrong, or maybe it's not possible to upgrade the system if you boot to a usb stick?
Thank you
Re: Rasp2 running on USB Stick, kernel upgrade problem
Thu Jun 22, 2017 8:39 pm
What device was mounted as /boot when you ran the upgrade?
What's in /lib/modules?
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
karvalho
Sat Jun 24, 2017 2:11 am
Before the upgrade, it seems /dev/sda1 is properly mounted.
mount | grep boot
/dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
/dev/mmcblk0p1 on /media/pi/boot type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
ls /lib/modules
4.4.50+  4.4.50-v7+
Sat Jun 24, 2017 7:04 am
Where's the root filesystem? What's in /boot/cmdline.txt? What's in /etc/fstab on that root filesystem?
karvalho
Sat Jun 24, 2017 12:05 pm
If I run "mount", the first line is this:
/dev/sda2 on / type ext4 (rw,noatime,data=ordered)
It means the root is mounted on my usb stick, right?
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=402e4a57-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet init=/usr/lib/raspi-config/init_resize.sh splash plymouth.ignore-serial-consoles
That UUID? blkid gives me
/dev/mmcblk0p1: LABEL="boot" UUID="95E0-9AC4" TYPE="vfat" PARTUUID="1f442c82-01"
/dev/mmcblk0p2: UUID="b105f9a8-f450-4976-8ac8-69053f57bab4" TYPE="ext4" PARTUUID="1f442c82-02"
/dev/sda1: LABEL="boot" UUID="95E0-9AC4" TYPE="vfat" PARTUUID="402e4a57-01"
/dev/sda2: UUID="b105f9a8-f450-4976-8ac8-69053f57bab4" TYPE="ext4" PARTUUID="402e4a57-02"
/dev/mmcblk0: PTUUID="1f442c82" PTTYPE="dos"
So I guess that's right, it mounts my usb stick as root, right?
In my sd card, cmdline.txt has this:
cat /media/pi/boot/cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
cat /etc/fstab
proc            /proc           proc    defaults          0       0
PARTUUID=402e4a57-01  /boot           vfat    defaults          0       2
PARTUUID=402e4a57-02  /               ext4    defaults,noatime  0       1
Thank you for your patience, sir.
karvalho
Sat Jun 24, 2017 12:14 pm
BTW, after upgrading, /lib/modules has these:
ls /lib/modules
4.9.28+  4.9.28-v7+
But the sd card's /lib/modules still have the files from the original kernel:
ls /media/pi/b105f9a8-f450-4976-8ac8-69053f57bab4/lib/modules
4.4.50+  4.4.50-v7+
And
uname -r
4.4.50-v7+
runboy93
Sat Jun 24, 2017 2:33 pm
Start from point 0.
karvalho
Sat Jun 24, 2017 5:09 pm
Start from point 0.
I just did, and got some interesting results. I managed to get the exact opposite result: uname -r reports a newer kernel, and /lib/modules contains older kernel files.
uname -r
4.9.28-v7+
ls /lib/modules
4.4.50+  4.4.50-v7+
depmod
depmod: ERROR: could not open directory /lib/modules/4.9.28-v7+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
I'm probably doing something terribly wrong, so here's all the steps I've taken.
1) I dd'd raspbian image to both devices: the sd card and the usb stick.
sudo dd bs=4M status=progress if=2017-04-10-raspbian-jessie.img of=/dev/sdd
2) I booted my rasp2 with only the sd-card. uname -r returns 4.4.50-v7+. sudo apt-get update and upgrade it. Reboot. Still working fine, uname -r returns 4.9.28-v7+. Great.
3) Then, I changed the root parameter in /boot/cmdline.txt to /dev/sda2, turned it off, plugged the usb stick, and turned it on.
And that's it. I was expecting uname -r to return the kernel version is in the usb stick, 4.4, not the sd card version, 4.9. It feels like I have a frankenstein, only parts of it are upgraded, and others aren't, and I really can't see what I'm doing wrong.
I'm gonna upgrade it again, now running on my usb stick, and see the results. Thank you.
itimpi
Sat Jun 24, 2017 11:04 pm
Sounds as if you upgraded the copy of Raspbian on the SD card and then failed to copy the upgraded Raspbian to the USB drive?
Alternatively if you had run step 2 while running with root on the USB stick then it would have upgraded the Boot related files in the boot partition on the SD card and then the main `Raspbian files on the USB stick.
karvalho
Sun Jun 25, 2017 11:35 am
That's correct. Is it required to keep both upgraded?
I've tried that several times, it leads to the original problem. The whole system gets upgraded, but not the boot partition, as uname -r reports the old kernel, and that kernel's files are missing on /lib/modules.
