Mettauk
Since update can't access WebIOpi via http
Tue May 02, 2017 8:55 am
Webiopi seems broken after RPI update/upgrade!
I can't access a web interface that controls some relays that was set up on port 8080 with WebIOPi. The port has been closed since the rpi update yesterday! PLUS all the relays come on at boot! Even though only one was set to high at boot!
Help!
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
Re: Since update can't access WebIOpi via http
Wed May 03, 2017 6:18 am
Are you running this version: http://webiopi.trouch.com/
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Mettauk
Wed May 03, 2017 7:36 am
DougieLawson wrote:Are you running this version: http://webiopi.trouch.com/
Have been running updated version for some years, I run Rpi update about once a month on all Pi. No problems until 1st May.
Just tried reinstalling WebioPi but port still not opening yet WebioPi seems to be running
Wed May 03, 2017 9:53 am
rpi-update is not recommended as it installs a testing and likely experimental kernel /firmware, yes things break.
In Raspbian Jesssie a stable kernel is installed via apt-get update & dist-upgrade ;)
On my 3B running Jessie fully updated "Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux"
adieu
Mettauk
Wed May 03, 2017 10:30 am
fruitoftheloom wrote: rpi-update is not recommended as it installs a testing and likely experimental kernel /firmware, yes things break.
Sorry not, I repeat not rpi update, just standard
apt-get update & dist-upgrade.
Same on 2 Pis' before I realised the update(s) were breaking so much
Mettauk
Mon May 22, 2017 5:11 pm
OK, a few weeks have passed and no solution to update/upgrade problem messing up WebIOpi and pan/tilt from mind sensors software. But now the update/upgrade also messes up I2C on PicoBorg Reverse (PiBorg) Reverting to an older kernal sorts it??? See https://www.piborg.org/node/2396
What is going on!
