melvonic.demon
Cannot determine i2c baud rate on rpi 3
Sun Apr 23, 2017 11:46 am
I have a rpi 3 and i was using the matlab support package for rpi but when i tried starting a connection with raspi() an error came up and i traced it back to it failing to read the i2c baud rate. The command they use is
sudo cat /sys/module/i2c_bcm2708/parameters/baudrate
When i run it it comes back as file not found. And checking the appropriate directory the file is not there but i2c works because i have an rtc connected to it. And ideas on why it doesn't exist?
I am using raspbian 2017 03 02 full and kernel 4.9.24
Melvin
mahjongg
Re: Cannot determine i2c baud rate on rpi 3
Sun Apr 23, 2017 11:54 am
I2C doesn't have a "baud rate" like a serial (UART) based communication system, there are however different varieties of I2C that can handle higher clock speeds than 100KHz, depending on the I2C chips used.
see https://en.wikipedia.org/wiki/I2C
Perhaps you can ask at the mathlab community forum.
melvonic.demon
Sun Apr 23, 2017 11:57 am
I was making a reference to the command used by matlab to determine the i2c speed. I referred to it as baudrate because the file is called baudrate. It doesn't work on my pi which is weird. Hence my confusion why would they put it if it wouldn't work? Matlab aside if i run the said command it should work.
Melvin
Last edited by melvonic.demon on Sun Apr 23, 2017 11:59 am, edited 1 time in total.
joan
Perhaps the command used to work on an older version of the kernel.
DirkS
Sun Apr 23, 2017 12:01 pm
I just checked and the file does exist on my pi3b (contains '0').
Did you activate I2C using raspi-config or the Raspberry Pi configuration utility?
joan
Sun Apr 23, 2017 12:02 pm
Recent Pis probably use i2c_bcm2835 rather than i2c_bcm2708. But i2c_bcm2835 doesn't have that parameter.
melvonic.demon
Sun Apr 23, 2017 12:04 pm
joan wrote:Perhaps the command used to work on an older version of the kernel.
Perhaps but when i lsmod i see a i2c_bcm2835 which i naturally substituted in place of the bcm2708 part but alas it doesn't work. I tried googling or my problem but nothing helpful was available. In reply to DirkS, i used raspi config to enable it. I tried disabling and enabling it.
Ok so if the newer pi doesn't have that command then how do i query my i2c speed?
Sun Apr 23, 2017 12:08 pm
melvonic.demon wrote:The command they use is
That's no longer there because the bcm2708 I²C driver got replaced with a bcm2835 version (I think around the time that the device tree came in (June 2015)). So your instructions must date back a long while.
Assume until you've measured it that it's fixed at 100,000 or go and read the code at https://github.com/raspberrypi/linux
This is a doctor free zone.
melvonic.demon
Sun Apr 23, 2017 12:12 pm
You have a point i can assume its 100khz but i would wonder why the folks at mathworks wouldn't know about this. How would i change the speed and verify it by checking some parameters on the system itself instead of actually measuring it? Guess i should report this to mathworks as well
Sun Apr 23, 2017 12:19 pm
Since you're paying real green $$$$s for your Matlab software you should contact their technical support (it's one of the things your $$$$s pay for).
melvonic.demon
Sun Apr 23, 2017 12:27 pm
DougieLawson wrote:Since you're paying real green $$$$s for your Matlab software you should contact their technical support (it's one of the things your $$$$s pay for).
Valid point again, i will be getting in contact with them soon. But back to the pi, how do i set the i2c baud rate or better still query it on the pi 3?
mahjongg
Sun Apr 23, 2017 12:33 pm
just from first principles, and what DirkS said, I assume you create a file called baudrate filled with a single ascii character '0' and place it at /sys/module/i2c_bcm2708/parameters/
as far as I understand this the RPI3 doesn't support anything but 100KHz, so querying for the clock speed parameter isn't needed/possible anymore.
melvonic.demon
Sun Apr 23, 2017 12:37 pm
mahjongg wrote:just from first principles, I assume you create a file called baudrate filled with a single ascii character '0' and place it at /sys/module/i2c_bcm2708/parameters/
I was looking at the dtoverlay and by default its a 100khz so no problem there, can i create that baudrate file and put 100000 instead, just to satisfy matlab? Till they fix it. On my system i can modify what i need but not on others.
davidcoton
Sun Apr 23, 2017 5:07 pm
melvonic.demon wrote:can i create that baudrate file and put 100000 instead, just to satisfy matlab?
Who knows? Try it and see. Unlikely to break anything :)
Signature retired
melvonic.demon
Sun Apr 23, 2017 5:15 pm
Tried that but normal mkdir with root privies doesn't work guess its because it's a system thing. For now i just modified the annoyances in matlab its working with the pi so that's fixed.
Thanks to everyone one for their help.
Melvin
ktb
Sun Apr 23, 2017 10:04 pm
See these threads:
viewtopic.php?f=66&t=176579
viewtopic.php?f=29&t=167934&start=125
The 4.9.x kernel has both the i2c_bcm2835 and i2c_bcm2708 modules. i2c_bcm2835 is the default.
Changing i2c_arm_baudrate still works with i2c_bcm2835. In /boot/config.txt:
dtparam=i2c_arm=on,i2c_arm_baudrate=32000
You can get the current value with something like this:
pi@raspberrypi:~$ var="$(xxd /sys/class/i2c-adapter/i2c-1/of_node/clock-frequency | awk -F': ' '{print $2}')"
pi@raspberrypi:~$ var=${var//[[:blank:].\}]/}
pi@raspberrypi:~$ printf "%d\n" 0x$var
32000
amcdonley
Tue Nov 12, 2019 2:54 pm
You can get the current value with something like this: ...
Thanks - I put your code into a file i2c_baudrate.sh (then chmod +x i2c_baudrate.sh):
#!/bin/bash
# Print current maximum i2c rate
printf "I2C Clock Rate: %d Hz\n" 0x$var
