Cast to ChromeCast not functioning in Chromium [SOLVED]
Posted: Mon Mar 13, 2017 7:00 pm
by fruitoftheloom
I have a fully up-to-date Raspbian Jessie install on my Raspberry Pi 3B
chromium-browser "Version 56.0.2924.84 Built on Ubuntu 14.04, running on Raspbian 8.0"
I usually use my ChromeCast from an Android Device works AOK. Unfortunately when use the Cast function from chromium-browser receive the message:
No Cast destinations found. Need help?
https://support.google.com/chromecast/answer/7249696
All my devices are connected to my wireless router, seems like this has been asked previously by Googling, but never resolved :?:
Re: Cast to ChromeCast not functioning in Chromium
Posted: Thu Apr 13, 2017 9:06 pm
by mika123
Have you found a solution?
I'm also seeing the same problem, which is quite frustrating, since it used to work fine with an earlier version of Chrome and the Cast extension :-\
Posted: Thu Apr 13, 2017 9:22 pm
by fruitoftheloom
mika123 wrote:Have you found a solution?
Unfortunately not found a way to resolve this issue :(
Posted: Thu Apr 13, 2017 10:11 pm
by mika123
fruitoftheloom wrote: Unfortunately not found a way to resolve this issue :(
Weird... and I couldn't find any workaround for this, or even many people complaining about it. :o
The only hope is reverting to Chrome 51 and triggering the extension install from https://www.google.com/chromecast/setup/
I don't know yet if the latest pixel image supports doing that though... I'll let you know
Posted: Wed Nov 15, 2017 1:42 pm
by fkbreitl
I see the same problem with Chromium Version 60.0.3112.89 (Developer Build) Built on Ubuntu 14.04, running on Raspbian 9.1 (32-bit).
I also found this bug report which seems related and fixed since November 4:
https://bugs.debian.org/cgi-bin/bugrepo ... bug=870619
This issue was also reported at
https://raspberrypi.stackexchange.com/q ... ing-jessie .
So it seems like the Chromecast casting is currently not working but in some month the fixed version of Chromium could make it into Raspbian.
Posted: Tue May 22, 2018 5:43 pm
by hippy
Just ran into the same problem myself; Pi 3B, Raspbian Stretch, Chromium 60.0.3112.89 - Same as reported back in November 2017 above.
Does anyone know when a later fixed version will be available ?
Posted: Wed May 23, 2018 8:05 am
by ShiftPlusOne
The current version of chromium in our repo should be 65. Are you sure you're up to date?
Posted: Wed May 23, 2018 11:04 am
by hippy
I thought I was, but it seems chromium and rpi-chromium-mods had been kept back. That's new or I had missed it previously.
Ran 'sudo apt-get dist-upgrade' and that appears to have resolved everything, can now find and cast to my Chromecast ...
pi@Pi3B:~$ uname -a
Linux Pi3B 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
pi@Pi3B:~$ chromium-browser --version
--disable-quic --enable-tcp-fast-open --disable-gpu-compositing
--ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so
--ppapi-flash-args=enable_stagevideo_auto=0
--ppapi-flash-version=
Chromium 65.0.3325.181 Built on Raspbian , running on Raspbian 9.4
pi@Pi3B:~$
Thanks for pushing me to double-check.
Posted: Tue Jul 24, 2018 10:42 am
by satomee
I'm just planning to buy a Raspberry Pi 3 B+ and one of the requirements would be to stream video to Chromecast. Reading the above I understand this can be done by using Chromium. But how can I do this if I don1t have any screens attached to the RPI?
Thanks in advance
Posted: Tue Jul 24, 2018 12:07 pm
by hippy
You can access the virtual desktop of the Pi via VNC, RDP or TeamViewer but it would seem to make more sense to initiate casting to a Chromecast from a device which directly supports that.
Perhaps provide more detail on what you are trying to achieve.
Re: Cast to ChromeCast not functioning in Chromium [solved]
Posted: Mon Jan 21, 2019 8:28 pm
by puccaso
Having the same issue right here.
mahir@txq:~/build/barrier/build $ chromium-browser --version
 --disable-quic --enable-tcp-fast-open --disable-gpu-compositing --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
Chromium 65.0.3325.181 Built on Raspbian , running on Raspbian 9.6
Any update on this?
Posted: Tue Jan 22, 2019 7:24 am
by fruitoftheloom
Any update on this?
What same issue ? I originally posted when running Raspbian Jessie, subsequently Raspbian Stretch and chromium-browser v65 have become available and casting is now working as per the post in June 2018.
Any posts newer than that I have ignored as have no relevance to original question.
Maybe you would be better served by starting your own Topic with a full explanation of the issues you are having ??
