jtiscione
Insanely slow network performance
Fri Mar 10, 2017 2:07 am
I installed a fresh Raspbian (PIXEL), and have it connected to a router via the Ethernet port. Why is the network performance so miserable? At most I can get about 10kb per second. Even typing in command lines involves waiting several seconds for keystrokes to appear. This is not a problem on any other machine, just the pi.
[EDIT 3/19/17: Just replaced my router and these problems with internal LAN performance went away. The pi now gets 90-100 Mbits/s.]
Ernst
Re: Insanely slow network performance
Fri Mar 10, 2017 7:53 am
jtiscione wrote:I installed a fresh Raspbian (PIXEL), and have it connected to a router via the Ethernet port. Why is the network performance so miserable? At most I can get about 10kb per second. Even typing in command lines involves waiting several seconds for keystrokes to appear. This is not a problem on any other machine, just the pi.
Why are the Raspberry Pi's network capabilities so atrocious?
You have a problem in the network configuration, this can be hardware and/or software.
If you need help then please give more information, like what Pi, which OS release, network configuration, active interfaces, system activity.
Btw. I get 9MByte/sec to a Pi 3.
The road to insanity is paved with static ip addresses
Fri Mar 10, 2017 10:14 am
They are not, you are blaming the Pi for something when it is not its fault. Don't you think that if the Pi was this bad people would have noticed? So there is an issue with you network setup, and to diagnose that more information is needed.
jahboater
Fri Mar 10, 2017 11:12 am
You can get up to around:-
$ iperf -c pi3
Client connecting to pi, TCP port 5001
TCP window size: 85.0 KByte (default)
[  3] local 192.168.0.8 port 48526 connected with 192.168.0.80 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-10.0 sec   382 MBytes   320 Mbits/sec
shuckle
Fri Mar 10, 2017 11:33 am
jahboater wrote:You can get up to around:-
$ iperf -c pi3
How did you do that? It is supposed to be difficult to get past 100M as the ethernet on Pi is only 100M.
I get
$ iperf -c pi10
Client connecting to pi10, TCP port 5001
[  3] local 192.168.254.229 port 47067 connected with 192.168.254.107 port 5001
[  3]  0.0-10.1 sec   116 MBytes  96.4 Mbits/sec
(My test linux and pi3 are on the same 1G switch.)
jahboater
Fri Mar 10, 2017 11:46 am
shuckle wrote: I get
$ iperf -c pi10
Sorry, thats with a USB adapter. Your figure is about right for the built-in ethernet.
I was just showing what the Pi is actually capable of.
jtiscione
Sun Mar 12, 2017 6:57 am
Ernst wrote:If you need help then please give more information, like what Pi, which OS release, network configuration, active interfaces, system activity.
This is a pi 3, with Raspbian PIXEL. As for "network configuration", "active interfaces", and "system activity", I'm not sure what you're asking for. The network configuration is Ethernet, plugged in to a standard router from an ISP.
jtiscione
Sun Mar 12, 2017 7:02 am
jamesh wrote:They are not, you are blaming the Pi for something when it is not its fault. Don't you think that if the Pi was this bad people would have noticed? So there is an issue with you network setup, and to diagnose that more information is needed.
Yes, I figure people would have noticed, and the fact that no one else is reporting this is what made me come here to ask. Everyone complaining about slow network performance is still reporting speeds that are still 10-100X what I'm seeing.
jtiscione
Sun Mar 12, 2017 7:15 am
This is what I'm seeing-
Connecting to host 192.168.0.24, port 5201
[  4] local 192.168.0.10 port 51899 connected to 192.168.0.24 port 5201
[  4]   0.00-1.00   sec   223 KBytes  1.83 Mbits/sec
[  4]   1.00-2.00   sec  75.7 KBytes   620 Kbits/sec
[  4]   2.00-3.00   sec  33.9 KBytes   277 Kbits/sec
[  4]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec
[  4]   4.00-5.00   sec  2.83 KBytes  23.2 Kbits/sec
[  4]   5.00-6.00   sec  4.24 KBytes  34.8 Kbits/sec
[  4]   6.00-7.00   sec  63.6 KBytes   522 Kbits/sec
[  4]   7.00-8.00   sec   320 KBytes  2.62 Mbits/sec
[  4]   8.00-9.00   sec  99.0 KBytes   810 Kbits/sec
[  4]   9.00-10.00  sec  42.2 KBytes   345 Kbits/sec
[  4]   0.00-10.00  sec   865 KBytes   708 Kbits/sec                  sender
[  4]   0.00-10.00  sec   737 KBytes   603 Kbits/sec                  receiver
Actually that's not as slow as I thought it was, but it's still pretty bad. I'm not sure where to start looking though.
PiGraham
Sun Mar 12, 2017 7:28 am
jahboater wrote:Sorry, thats with a USB adapter. Your figure is about right for the built-in ethernet.
What adaptor are you using?
Ernst
Sun Mar 12, 2017 7:34 am
Please enter the following commands from the command line/terminal:
man uname
man ifconfig
man route
after reading you can next enter the following commands:
uname -a
ifconfig -a
route
dhcpcd -U eth0
dhcpcd -U wlan0
jtiscione
Sun Mar 12, 2017 7:59 am
Ernst wrote:
uname -a
ifconfig -a
route
dhcpcd -U eth0
dhcpcd -U wlan0
Entering uname -a generates:
Linux raspberrypi 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
ifconfig -a :
eth0      Link encap:Ethernet  HWaddr b8:27:eb:d8:75:5c
          inet addr:192.168.0.24  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::5bb6:b847:6e61:1d11/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:14289301 errors:0 dropped:684 overruns:0 frame:0
          TX packets:13701734 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2000635982 (1.8 GiB)  TX bytes:2993440958 (2.7 GiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:96680 errors:0 dropped:0 overruns:0 frame:0
          TX packets:96680 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6114754 (5.8 MiB)  TX bytes:6114754 (5.8 MiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:8d:20:09
          inet addr:192.168.0.99  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::f55c:b69a:61ec:f566/64 Scope:Link
          RX packets:2574236 errors:0 dropped:173601 overruns:0 frame:0
          TX packets:7915 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:460699818 (439.3 MiB)  TX bytes:991117 (967.8 KiB)
route :
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         modem.Home      0.0.0.0         UG    202    0        0 eth0
default         modem.Home      0.0.0.0         UG    303    0        0 wlan0
192.168.0.0     *               255.255.255.0   U     202    0        0 eth0
192.168.0.0     *               255.255.255.0   U     303    0        0 wlan0
dhcpcd -U eth0 :
broadcast_address='192.168.0.255'
dhcp_lease_time='86400'
dhcp_message_type='5'
dhcp_server_identifier='192.168.0.1'
domain_name='Home'
domain_name_servers='192.168.0.1 205.171.3.25'
ip_address='192.168.0.24'
network_number='192.168.0.0'
routers='192.168.0.1'
subnet_cidr='24'
subnet_mask='255.255.255.0'
dhcpcd -U wlan0 generates the same output except for the line ip_address='192.168.0.19'.
Ernst
Sun Mar 12, 2017 8:03 am
Did you have a look the output ?
I can see at least three or more problem.
I suggest you start with reading the ifconfig output for wlan0
jtiscione
Sun Mar 12, 2017 8:24 am
What 3 problems? What's interesting about the output from ifconfig wlan0?
Ernst
Sun Mar 12, 2017 8:52 am
You were able to decide that the pi network capabilities so atrocious but you are unable to notice the problems in your network. May I remind you that the the Pi is about learning and this is something you have to do for yourself, we are just here to assist you when needed.
Did you notice the following line ?
This is a 6% failure rate on your wifi, this must not be important but it is something that may need attention, normally the next that would be noticed is the same line under eth0:
Better, can be ignored at this low rate.
What is more important are the following two lines:
eth0: inet addr:192.168.0.24 Bcast:192.168.0.255 Mask:255.255.255.0
wlan0: inet addr:192.168.0.99 Bcast:192.168.0.255 Mask:255.255.255.0
This is not good, either disable one interface or use a different subnet.
The reason can be seen below:
As you can see above you have two routes into the same network, but the first route has a lower metric (=higher priority). Under unfavorable conditions(*) it may happen that traffic is routed over both interfaces so that the slowest interface reduces the performance.
(*) What is the operating system on the other machine used with iperf ? How many network interfaces does this system have ?
I suggest you disable and/or remove the wlan0 interface and try again.
jtiscione
Sun Mar 12, 2017 9:20 am
Ernst- Sorry if I gave the wrong impression with the original post. I was referring to this particular pi on my network, not meaning to insult all raspberry pis in general. This is not the pi's "fault", it's obviously the network, but among the machines here I only had this problem on the pi.
But disabling wlan0 now gives me from iperf3
Accepted connection from 192.168.0.10, port 53704
[  5] local 192.168.0.24 port 5201 connected to 192.168.0.10 port 53705
[  5]   0.00-1.00   sec  4.78 MBytes  40.1 Mbits/sec
[  5]   1.00-2.00   sec  5.21 MBytes  43.7 Mbits/sec
[  5]   2.00-3.00   sec  4.42 MBytes  37.1 Mbits/sec
[  5]   3.00-4.00   sec  4.29 MBytes  36.0 Mbits/sec
[  5]   4.00-5.00   sec   505 KBytes  4.14 Mbits/sec
[  5]   5.00-6.00   sec   536 KBytes  4.39 Mbits/sec
[  5]   6.00-7.00   sec   281 KBytes  2.31 Mbits/sec
[  5]   7.00-8.00   sec  1.77 MBytes  14.8 Mbits/sec
[  5]   8.00-9.00   sec  2.19 MBytes  18.4 Mbits/sec
[  5]   9.00-10.00  sec  6.85 MBytes  57.4 Mbits/sec
[  5]  10.00-10.02  sec   164 KBytes  75.4 Mbits/sec
[  5]   0.00-10.02  sec  31.2 MBytes  26.1 Mbits/sec                  sender
[  5]   0.00-10.02  sec  31.0 MBytes  25.9 Mbits/sec                  receiver
Disabling wlan0 sped it up almost by a factor of a hundred. (WTF?) Thank you very much!
-Jason
Ernst
Sun Mar 12, 2017 9:50 am
It has gotten better but still not good enough. There must be something else that is causing some problems because there is too much variation in your results. Just take a look at the following using a Pi3 on ethernet to a Pi 0 W, there are two ethernet switches between the Pi 3 and the access point, the Pi 0 W is one floor below the access point:
pi@raspi3:~ $ iperf3 -c raspi4
Connecting to host raspi4, port 5201
[  4] local 192.168.0.230 port 46512 connected to 192.168.0.235 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  4.54 MBytes  38.0 Mbits/sec    2    170 KBytes
[  4]   1.00-2.00   sec  3.81 MBytes  32.0 Mbits/sec    0    182 KBytes
[  4]   2.00-3.00   sec  4.62 MBytes  38.8 Mbits/sec    0    198 KBytes
[  4]   3.00-4.00   sec  4.21 MBytes  35.4 Mbits/sec    0    214 KBytes
[  4]   4.00-5.00   sec  3.91 MBytes  32.8 Mbits/sec    0    225 KBytes
[  4]   5.00-6.00   sec  3.52 MBytes  29.5 Mbits/sec    0    257 KBytes
[  4]   6.00-7.00   sec  4.24 MBytes  35.6 Mbits/sec    0    320 KBytes
[  4]   7.00-8.00   sec  4.10 MBytes  34.4 Mbits/sec    0    404 KBytes
[  4]   8.00-9.00   sec  4.67 MBytes  39.2 Mbits/sec    0    518 KBytes
[  4]   9.00-10.00  sec  3.54 MBytes  29.6 Mbits/sec    0    645 KBytes
[  4]   0.00-10.00  sec  41.2 MBytes  34.5 Mbits/sec    2             sender
[  4]   0.00-10.00  sec  40.8 MBytes  34.2 Mbits/sec                  receiver
iperf Done.
This time between two Pi 3
pi@raspi3:~ $ iperf3 -c raspi2
Connecting to host raspi2, port 5201
[  4] local 192.168.0.230 port 33776 connected to 192.168.0.249 port 5201
[  4]   0.00-1.00   sec  11.3 MBytes  94.6 Mbits/sec    0   35.4 KBytes
[  4]   1.00-2.00   sec  11.2 MBytes  94.2 Mbits/sec    0   38.2 KBytes
[  4]   2.00-3.00   sec  11.2 MBytes  94.1 Mbits/sec    0   39.6 KBytes
[  4]   3.00-4.00   sec  11.2 MBytes  94.2 Mbits/sec    0   43.8 KBytes
[  4]   4.00-5.00   sec  11.3 MBytes  94.4 Mbits/sec    0   59.4 KBytes
[  4]   5.00-6.00   sec  11.2 MBytes  94.0 Mbits/sec    0   59.4 KBytes
[  4]   6.00-7.00   sec  11.3 MBytes  94.4 Mbits/sec    0   59.4 KBytes
[  4]   7.00-8.00   sec  11.2 MBytes  94.1 Mbits/sec    0   59.4 KBytes
[  4]   8.00-9.00   sec  11.2 MBytes  94.1 Mbits/sec    0   59.4 KBytes
[  4]   9.00-10.00  sec  11.2 MBytes  94.1 Mbits/sec    0   59.4 KBytes
[  4]   0.00-10.00  sec   112 MBytes  94.2 Mbits/sec    0             sender
[  4]   0.00-10.00  sec   112 MBytes  94.2 Mbits/sec                  receiver
iperf Done.
What you can see above is that there is a very little variance in the performance, your measurement shows a lot of variance:
There can be many reasons and it can be very difficult to find the cause as it can be anywhere in the network. The first item to check is the power supply, then the ethernet cable.If this does not bring up anything you will have check everything connected to find what could be causing the problems.
EDIT: Is the other system that you are using for iperf using a wireless interface ? In that case your measurement may make sense.
jtiscione
Sun Mar 12, 2017 10:23 am
I ran iperf3 -c pi3 on this mac which is connected via wireless, so that could be the source of the fluctuation. It's better than it was but it's still pretty crazy:
  4] local 192.168.0.10 port 55278 connected to 192.168.0.24 port 5201
[  4]   0.00-1.00   sec   218 KBytes  1.79 Mbits/sec
[  4]   1.00-2.00   sec  86.3 KBytes   707 Kbits/sec
[  4]   2.00-3.00   sec  67.9 KBytes   556 Kbits/sec
[  4]   4.00-5.00   sec   563 KBytes  4.61 Mbits/sec
[  4]   5.00-6.00   sec  6.02 MBytes  50.5 Mbits/sec
[  4]   6.00-7.00   sec  8.17 MBytes  68.6 Mbits/sec
[  4]   7.00-8.00   sec  7.85 MBytes  65.9 Mbits/sec
[  4]   8.00-9.00   sec  1.12 MBytes  9.41 Mbits/sec
[  4]   9.00-10.00  sec   223 KBytes  1.82 Mbits/sec
[  4]   0.00-10.00  sec  24.3 MBytes  20.4 Mbits/sec                  sender
[  4]   0.00-10.00  sec  24.2 MBytes  20.3 Mbits/sec                  receiver
jahboater
Sun Mar 12, 2017 10:41 am
https://www.amazon.co.uk/Unibody-Alumin ... +with+rj45
Its a bit pricey but Anker stuff is well made. No drivers are needed.
Not all USB ethernet adapters will give that sort of speed.
