SteveSpencer
Updating a downloaded image
Wed Mar 01, 2017 11:30 am
What I want to do is relatively simple. I want to take a downloaded .img file, on a Pi, and bring it up to date in terms of having the latest version of packages (including the kernel).
In this way, I would avoid having to run
 apt-get update && apt-get dist-upgrade
when I copy the image to a card and boot the pi.
I have previously made use of mount with a loop device to mount the boot partition and copy an empty ssh file and a wpa_supplicant.conf file to it so that I can boot headless (which in theory I can do from a Windows machine anyway).
I also mounted the root partition as well, and was able to access that successfully.
I did think that mounting the root, and using chroot /mountpoint ... would allow me to do this.
Of course, I would also have to mount the boot partition under the mount point's boot directory first, or updating the kernel and/or any overlays wouldn't work.
So, two questions:
1. Is what I want to do possible?
(I recognise that I would have to regularly run the process to keep the image updated)
2. Does the mechanism I describe allow me to do such a thing?
Thanks in advance for any advice, experience, or general comments.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
SteveSpencer
Re: Updating a downloaded image
Wed Mar 01, 2017 12:57 pm
Hmm. The short answer is yes and no.
I can do Jessie lite, but not full Jessie, since it runs out of space :(
However, for this particular use-case that's fine, since I am producing headless images for Pi Zero (and Zero W!) anyway.
Steve S
Wed Mar 01, 2017 1:01 pm
SteveSpencer wrote:Hmm. The short answer is yes and no.
?? DietPi http://dietpi.com
Retired disgracefully.....
......to a more gentile life !
