I don't understand dmesg message
Posted: Sun Feb 19, 2017 4:48 pm
by Canedje
After running dmesg command I do recieve a lot lines all telling the same.
I don't understand the message. Can somebody help?
[155442.835970] w1_master_driver w1_bus_master1: Family 0 for 00.113000000000.ee is not registered.
Re: I don't understand dmesg message
Posted: Mon Feb 20, 2017 11:05 am
by epoch1970
Posted: Mon Feb 20, 2017 12:01 pm
by Canedje
Thanks.
Strange because I'm not using W1 at this moment
Posted: Mon Feb 20, 2017 12:22 pm
by rpdom
If the w1 driver is loaded but no devices are connected, it will pick up phantom devices, which is what you are seeing.
Comment out the "dtoverlay=w1-gpio" line in /boot/config.txt, disable it using raspi-config or remove it from your /etc/modules (if present).
