denpoon
is the raspian mirror server down?
Fri Jan 13, 2017 7:14 am
I JUST TRIED:
apt-get install python-mysql.connector
But got this error:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-mysql.connector all 1.2.3-2
Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... -2_all.deb Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried apt-get update but failed similarly
Please help.
My original sense hat Pi SD Card died and I need to install a new Raspbian + python + mysql asap to reduce the down time of recording the air pressure.
Thanks in advance.
MaxK1
Re: is the raspian mirror server down?
Fri Jan 13, 2017 7:32 am
It appears it is down- It was working about an hour or so ago. Give it a little time and try again.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Martin Frezman
Fri Jan 13, 2017 7:44 am
OK - I was about to post, asking if this was a systemic problem or just a "middle of the night problem" - i.e., a "try again later".
Here's the message I get when doing apt-get update:
root@jessie:/home/pi# apt-get update
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:2 http://archive.raspberrypi.org jessie/main Sources [54.8 kB]
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:3 http://archive.raspberrypi.org jessie/main armhf Packages [136 kB]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Fetched 214 kB in 6s (31.0 kB/s)
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
If this post appears in the wrong forums category, my apologies.
4LULZ
Fri Jan 13, 2017 8:21 am
I'm having the same issue trying to install OpenVPN, booting from a fresh install of the 2017-01-11 release where the one and only setting that's been changed was to enable SSH.
Guess it's time to fire up a game and give this a shot tomorrow :)
Fri Jan 13, 2017 9:35 am
There appears to be a glitch in the Matrix !!
Retired disgracefully.....
aupi
Fri Jan 13, 2017 9:42 am
Yup not working for me as well.
kazz
Fri Jan 13, 2017 10:39 am
Same for me
This is the error:
Just done a fresh install.
Anyone know if there is a work around mirror?
DirkS
Fri Jan 13, 2017 11:06 am
kazz wrote:Anyone know if there is a work around mirror?
You could (temporarily) change the URL in /etc/apt/sources.list to one of the mirrors: https://www.raspbian.org/RaspbianMirrors
4LULZ
Fri Jan 13, 2017 11:10 am
It's back up...
denpoon
Fri Jan 13, 2017 11:40 am
it is finally normal now.
SteveSpencer
Fri Jan 13, 2017 12:39 pm
Not quite. Still reporting an issue for Jessie/ui sources
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
DirkS
Fri Jan 13, 2017 12:45 pm
SteveSpencer wrote:Not quite. Still reporting an issue for Jessie/ui sources
IIRC 'ui' is only on the RPF repo, not the Raspbian...
I don't get any errors on that BTW
SteveSpencer
Fri Jan 13, 2017 1:46 pm
To be clear,
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main Sources
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Err http://archive.raspberrypi.org jessie/ui Sources
  406  Not Acceptable [IP: 46.235.227.11 80]
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/ui/source/Sources  406  Not Acceptable [IP: 46.235.227.11 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Steve S
denpoon
Fri Jan 13, 2017 3:21 pm
Too bad. I turned out it was only partially normal. When I tried
apt-get install libmysqlclient-dev
it got another error:
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u1_all.deb 404 Not Found [IP: 5.153.225.207 80]
Hope the admin notice this error and fix it soon.
Fri Jan 13, 2017 3:51 pm
Looks like the server is triksadecaphobic. Judging by today's date.
This is a doctor free zone.
DirkS
Fri Jan 13, 2017 4:21 pm
DougieLawson wrote:Looks like the server is triksadecaphobic. Judging by today's date.
Or even friggatriskaidekaphobic / paraskevidekatriaphobic
Paulwood
Wed Jan 18, 2017 1:32 pm
looks like ther is a problem today
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... ce/Sources 406 Not Acceptable [IP: 93.93.128.230 80]
ShiftPlusOne
Wed Jan 18, 2017 1:34 pm
Paulwood wrote:looks like ther is a problem today
Looks okay from this end.
ZzyzxWolfe
Contact: ICQ Yahoo Messenger AOL
Thu Aug 10, 2017 3:24 am
With the "406 Not Acceptable" error with apt-get, it seems to happen when apt tries to resume a partial download and the server doesn't support it.
If you get the "406 Not Acceptable" error, you can fix it by deleting the partially downloaded files from inside /var/lib/apt/lists/partial.
You can delete the partial downloads by running:
sudo rm /var/lib/apt/lists/partial/*
Then run:
sudo apt-get update
It should take care of the issue!
Hope this helps!
Cheers,
Zzyzx
“Don't lose your mind trying to set it free...”
amcdonley
Tue Oct 31, 2017 11:45 am
http://mirrordirector.raspbian.org/raspbian/ is not working for me at the moment, so tried:
deb http://raspbian.mirrors.wvstateu.edu/raspbian/ stretch main contrib non-free rpi
but that got a 404 on stretch/armhf
and then it also stuck on connecting to archive.raspberrypi.org
guess I'll have to go to work after all. I was contemplating "hookey" today.
