Canedje
how automatic desktop login at startup
Sat Nov 05, 2016 8:50 pm
In raspi-config you have 4 options how to start up at reboot.
there are two options for desktop GUI.
Automatic as pi or with different user and loging.
Is it possible to have also an automatic login as a different user then the standard pi login?
JimmyN
Re: how automatic desktop login at startup
Sun Nov 06, 2016 9:23 am
Yes you can do that, you just have to edit a file and change the default username.
If you want autologin to the desktop
sudo nano /etc/lightdm/lightdm.conf
Scroll down to near the bottom of the file till you find the line "autologin-user=pi" and change the user name.
Save and exit nano and you're all set.
If you want autologin to the console, rather than the desktop, then do this edit.
sudo nano /etc/systemd/system/autologin@.service
Scroll down until you see the line "ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM", and change the user name.
Canedje
Mon Nov 07, 2016 8:48 am
Thanks very much
