sirus
Terminal Freezing after installing OpenVPN
Wed Jul 20, 2016 7:56 am
HI guys,
I am using the brillaint build by AikonCWD (Mediacenter Kodi 15.1) which works fine. However I am when trying to install OpenVPN from a kodi repo I am getting errors that OpenVPN is unavailable. So in terminal I have done apt-get install OpenVPN to get it and volila the Kodi repo works.
Now, the problem is when I decided to go back into terminal for other stuff by keyboard does work. I have to unplug it and plug it back in which is annoying. Also had a working xbox controller prior to installing OpenVPN but now its not working.
Just curious if anyone knows what to do or a work around. Essentially I would like to use a vpn that accepts my PIA credentials.
Thanks.
