guarriman
ssh: Permission denied, please try again.
Sat May 28, 2016 12:26 pm
Hi.
I have just installed raspbian on a Raspberry Pi 1 Model B, and I am trying to connect it via ssh.
I enabled 'ssh' via 'raspi-config', changed the password of 'pi' user from the default to another new one, and I tried from another PC:
# ssh pi@192.168.1.100
But I get this error message:
pi@192.168.1.100's password:
What am I doing wrong? Thank you very much.
B.Goode
Re: ssh: Permission denied, please try again.
Sat May 28, 2016 2:17 pm
I can think of 3 possibilities - there may be others:
1. You have mis-remembered your new password;
2. Your ssh client is getting the mapping of some obscure symbol wrong;
3. 192.168.1.100 is not the IP address of your RPi.
guarriman
Sat May 28, 2016 2:53 pm
Thank you very much for your answer, B.Goode.
I have just ssh-ed within the raspberry (not from the external PC)
and it worked ok. So:
Discarded.
It is a very simple password (only letters, even no digits), and my client is the Ubuntu terminal. I have no problems ssh-ing other servers.
Discarded.
Sat May 28, 2016 5:04 pm
Ok, try
ssh -v pi@192.168.1.100
and post the output here.
guarriman
Sat May 28, 2016 7:23 pm
This is the output
jimmy@myPC:~/.ssh$ ssh -vv pi@192.168.1.100
OpenSSH_7.2p2 Ubuntu-4ubuntu1, OpenSSL 1.0.2g-fips  1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "192.168.1.100" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.1.100 [192.168.1.100] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/jimmy/.ssh/id_rsa type -1
debug1: Found key in /home/jimmy/.ssh/known_hosts:1
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug2: key: /home/jimmy/.ssh/id_rsa ((nil))
debug2: key: /home/jimmy/.ssh/id_dsa ((nil))
debug2: key: /home/jimmy/.ssh/id_ecdsa ((nil))
debug2: key: /home/jimmy/.ssh/id_ed25519 ((nil))
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/jimmy/.ssh/id_rsa
debug1: Trying private key: /home/jimmy/.ssh/id_dsa
debug1: Trying private key: /home/jimmy/.ssh/id_ecdsa
debug1: Trying private key: /home/jimmy/.ssh/id_ed25519
debug2: we did not send a packet, disable method
debug1: Next authentication method: password
debug2: we sent a password packet, wait for reply
Sat May 28, 2016 7:53 pm
Curious... there's quite a few lines that I would expect to be in there that aren't. Especially ones something like
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Raspbian-5+deb8u2
debug1: match: OpenSSH_6.7p1 Raspbian-5+deb8u2 pat OpenSSH* compat 0x04000000
That's running from my Ubuntu system to a Pi2 running Raspbian Jessie.
guarriman
Sat May 28, 2016 8:05 pm
Sorry, I must have removed some lines.
This is a copypaste:
jimmy@myPC:~/.ssh$ ssh -v pi@192.168.1.100
debug1: identity file /home/jimmy/.ssh/id_rsa type 1
debug1: identity file /home/jimmy/.ssh/id_rsa-cert type -1
debug1: identity file /home/jimmy/.ssh/id_dsa type -1
debug1: identity file /home/jimmy/.ssh/id_dsa-cert type -1
debug1: identity file /home/jimmy/.ssh/id_ecdsa type -1
debug1: identity file /home/jimmy/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/jimmy/.ssh/id_ed25519 type -1
debug1: identity file /home/jimmy/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.2p2 Ubuntu-4ubuntu1
debug1: match: OpenSSH_7.2p2 Ubuntu-4ubuntu1 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.1.100:22 as 'pi'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:jN2kWx4QPAe6jR5iJXgDmtYogwwZkfaL+ryqUHOPStM
debug1: Host '192.168.1.100' is known and matches the ECDSA host key.
debug1: Offering RSA public key: /home/jimmy/.ssh/id_rsa
Sat May 28, 2016 8:30 pm
Who owns /home/pi/.ssh and the files in there? What are the permission bits for those?
pi@pi-client:~/.ssh $ ls -la
total 24
drwx------  2 pi pi 4096 May 23 23:17 .
drwxr-xr-x 24 pi pi 4096 May 27 20:04 ..
-rw-------  1 pi pi  392 May  8 18:55 authorized_keys
-rw-------  1 pi pi 1675 May 23 23:17 id_rsa
-rw-r--r--  1 pi pi 1998 May 23 23:04 known_hosts
-rw-r--r--  1 pi pi  394 May 23 23:17 id_rsa.pub
Sat May 28, 2016 8:43 pm
guarriman wrote:3. 192.168.1.100 is not the IP address of your RPi.
Discarded.
Incorrect answer.
guarriman wrote:Sorry, I must have removed some lines.
That clearly shows that you are trying to connect to a system running Ubuntu, not Raspbian. Compare it to the lines I posted
which show Raspbian as the remote system being connected to.
B.Goode
Sat May 28, 2016 8:49 pm
As @rpdom points out, I am sticking with my Option #3.
Sun May 29, 2016 8:12 am
There's two easy ways to find an RPi's IP address
On the RPi
hostname -I # capital eye not ell
From any other machine
nmap -v -sn 192.168.1.0/24
or Fing from https://www.fingbox.com/
techri
Sat Nov 25, 2017 6:41 am
When i try to ssh into my pi i get a "Sorry try again" error
it doesn't say permission denied. I'm wondering if it's the same error your'e getting ?
jbirriel84
Tue Jan 15, 2019 5:13 am
When you login from Ubuntu you have to type ssh pi@(your pi's ip address) replace your pi's ip address with the ip address of your pi, then hit enter it should prompt you to enter the password this will be the password for the pi. If you just type ssh and then the pi ip address it does not work, it will say permission denied when you enter the password even if the password is correct. The raspberry pi I tried it on has the username pi, if for some reason ssh pi@(ip address) does not work and you have a different username try ssh username@(ip address). Hope it helps.
