I accidentally my command prompt!
Posted: Wed May 11, 2016 2:38 pm
by blaablaaguy
Foolishly, i set my pi to boot at the command line instead of the gui. Upon rebooting i dont get a command promt any more, just a terminal with a flashing cursor thingy and when i type and enter a command nothing happens. :( Im using berryboot and because of that i can acess config.txt and cmndline.txt.
Re: What happened to my command prompt?
Posted: Wed May 11, 2016 6:14 pm
by blaablaaguy
Bumpity bump.
Posted: Wed May 11, 2016 11:34 pm
by liz
OP - a bump after only four hours is a bit much. Please try to kerb your enthusiasm!
Posted: Thu May 12, 2016 12:38 am
by kusti8
Sounds like you may have run out of space. Can you check from BerryBoot or a Linux computer?
Posted: Thu May 12, 2016 4:05 am
by tweak42
blaablaaguy wrote:Foolishly, i set my pi to boot at the command line instead of the gui. Upon rebooting i dont get a command promt any more, just a terminal with a flashing cursor thingy and when i type and enter a command nothing happens. :( Im using berryboot and because of that i can acess config.txt and cmndline.txt.
Just a wild guess, but can you try changing tty terminals? You do this with key sequence:
Ctrl-Alt-F1 through F6. F7 should be the GUI but could end up with the blinking cursor you're describing (because you disabled the GUI).
Posted: Thu May 12, 2016 9:54 am
by blaablaaguy
Tried that allready. All are empty exept for f1 and f2. F1 displays a bit text, i think its like the top bit of the stuff that normally comes when i boot. F2 shows " [ OK ] Created slice system-getty.slice."
kusti8 wrote:Sounds like you may have run out of space. Can you check from BerryBoot or a Linux computer?
Ive got about a gigabyte left.
Posted: Thu May 12, 2016 9:57 am
by blaablaaguy
I can access the berryboot console but dont know the username and password. The default pi details dont work. Tried changing terminals and have a gigabyte space left.
Posted: Thu May 12, 2016 11:07 am
by blaablaaguy
liz wrote:OP - a bump after only four hours is a bit much. Please try to kerb your enthusiasm!
:oops: Sorry, i have yet to master the art of patience
Re: I accidentally my command prompt!
Posted: Thu May 12, 2016 11:18 am
by blaablaaguy
I might just reinstall my os. Ive got most of my python scripts backed up.
Posted: Thu May 12, 2016 11:57 pm
by tweak42
blaablaaguy wrote:I might just reinstall my os. Ive got most of my python scripts backed up.
Do you have another micro SD card? You could do a clean install and import your old stuff into it. If you are using windows you can use a ext4 reader program to recover your stuff off the data partition.
http://www.howtogeek.com/112888/3-ways- ... m-windows/
