Always show color rectangle on corner
Posted: Wed May 04, 2016 5:49 am
by billcruse
Hi everyone!
I custom embedded linux system for our project. but I find x-windows always show color rectangle on top-right corner.
How to hide it?
Re: Always show color rectangle on corner
Posted: Wed May 04, 2016 5:58 am
by liz
The rainbow square is a warning signal: it means your power supply is inadequate. For Pi 3 you need 2.5 amps; for Pi 2, 2 amps. If you don't meet these requirements the rainbow square will display, and you may find your Raspberry Pi crashes under load.
Posted: Wed May 04, 2016 6:02 am
by rpdom
Use a better power supply.
The small coloured square in the top right corner means that the Pi isn't getting the 5V it needs on the power input.
This may be caused by a PSU that is not good enough, or a too thin micro USB power cable.
