neo_star
RPi restarts continously help... (solved)
Sat Aug 11, 2012 12:46 pm
I see a coloured splash screen and can also see the console booting up for 1 sec
but after that it goes back to coloured splash screen and boot up after and after again
kernal image : 2012-07-15-wheezy-raspbian.zip
I use a Sandisk Sd card 4 GB class 4
I have connected it to a sont led tv thru HDMI
neo_star
Re: RPi restarts continously help...
Sat Aug 11, 2012 1:04 pm
I am using a iphone charger for this
its rated at 1A
mahjongg
Sat Aug 11, 2012 1:37 pm
It may be "rated 1A", but this behaviour is typical for a supply that cannot provide enough power, the moment it is asked to do so the output voltage collapses, and reset the PI.
It could be that the "USB power cable" is too long, and/or too thin, and causes too much energy loss.
Try another power supply.
neo_star
Sat Aug 11, 2012 1:49 pm
mahjongg wrote:It may be "rated 1A", but this behaviour is typical for a supply that cannot provide enough power, the moment it is asked to do so the output voltage collapses, and reset the PI.
i tried it with laptop usb
i am using a 1 feet cable
i ll try using a power adapter
joan
Sat Aug 11, 2012 2:56 pm
I think laptops only supply 0.5 amps per USB port. You could try one of those Y cables which are sometimes used to power usb drives from two usb ports.
Jim JKla
Sat Aug 11, 2012 3:48 pm
Best to try from a powered USB hub if you can get your hands on one.
neo_star
Sun Aug 26, 2012 6:01 pm
The problem was my usb cable
i changed the cable it worked
Jim JKla
Sun Aug 26, 2012 6:03 pm
As good as it gets. :D
