KYkid85
Overclock question
Wed Mar 30, 2016 7:29 pm
So config.txt script show im running 700MHz(default at safe)
Sudo raspi-config shows I'm running at 900MHz(which says default to safe)
Basically system reads config.txt=700MHZ. Terminal sudo raspi-config =900. Which is correct?
Re: Overclock question
Wed Mar 30, 2016 7:35 pm
You can check the current max and min clock speeds by checking these "files" in /sys
pi@raspi3 $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
600000
pi@raspi3 $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
900000
That shows that my Pi2 will idle at 600MHz, but increase to 900MHz when busy.
KYkid85
Sun Apr 03, 2016 5:10 pm
So i did exactly as written.
But...
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq(and scaling_max_freq) says its not a directory
/sys/devices/system/cpu/cpu0/cpufreq is accessable though
FYI
When i hit ls. sys/devieces/system/cpu/cpu0/cpufreq $ ls
it shows 14 items(none are bold btw)
I've had issues with Noobs to where some items did not download properly and had to Config.txt some items per legitimate help too
Thoughts?
GTR2Fan
Sun Apr 03, 2016 5:58 pm
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
