NOOBS 1.8 - removing and expanding a neighbour partiton
Posted: Wed Mar 16, 2016 9:14 am
by typxxi
Hey,
I've installed NOOBS 1.8 with the options RASPBIAN and OPENELEC and 512 MB Partition
The system run fine until I ran out of space, but I had luck to have made a backup before the java installation.
I was able to restore my image and that works fine, but only 37 MB space left.
Then I started to delete unwanted stuff like the 512 MB partition (meanwhile I was able to mount a 64 GB USB stick).
That worked fine.
As you can see behind partition 7 (/dev/mmcblk0p7) there are 512 MB of space (sector 11083774 - 12132351) and the same for partition 8 (/dev/mmcblk0p8)
Device         Boot    Start      End  Sectors  Size Id Type
/dev/mmcblk0p1          8192  2289062  2280871  1,1G  e W95 FAT16 (LBA)
/dev/mmcblk0p2       2289063 15548415 13259353  6,3G  5 Extended
/dev/mmcblk0p5       2293760  2359293    65534   32M 83 Linux
/dev/mmcblk0p6       2359296  2488319   129024   63M  c W95 FAT32 (LBA)
/dev/mmcblk0p7       2490368 11083773  8593406  4,1G 83 Linux
/dev/mmcblk0p8      12132352 14499837  2367486  1,1G 83 Linux
How can I expand the partitions 7 and 8 ?
My first try with a windows 10 Add On Partition Tool did not work and I was not able to find a solution on github.
Thx a lot
Re: NOOBS 1.8 - removing and expanding a neighbour partiton
Posted: Wed Mar 16, 2016 10:36 am
by fruitoftheloom
parted in Linux: http://linux.die.net/man/8/parted
Though be careful of NOOBS partitioning scheme: https://github.com/raspberrypi/noobs/wi ... -explained
Posted: Wed Mar 16, 2016 10:54 am
by ShiftPlusOne
fruitoftheloom wrote:parted in Linux: http://linux.die.net/man/8/parted
I believe the settings partition has moved a bit, so that page is not entirely accurate. The settings partition is now one of the logical partitions.
Posted: Wed Mar 16, 2016 10:58 am
by fruitoftheloom
Well it is about time NOOBS was updated then so the information matches the release. :roll:
Posted: Wed Mar 16, 2016 12:50 pm
by typxxi
Hey,
that noobs sd, where I had deleted the formerly 512 MB data partition for each OS (raspbian and openelec), did still boot and work in both OS. My problem is the linux / debian / raspbian command I have to use to expand my raspbian and my openelec partition to get first additional 512 MB.
You can see the gap in the sectors between partition 7 and 8:
Partition 7 can be extended from 11083773 to 12132351 - additional 512 MB
Partition 8 can be extended from 14499837 to 15548415 - additional 512 MB
When I installed NOOBS I did not realize that my 8 GB could become soon to small.
When I installed it with NOOBS I did not know that
#1 the image itself would be there as a recovery (there was a warning, when I installed, that everything will be lost)
#2 that raspbian need about 3 GB or 4 GB and openelec on top 1 GB
#3 that data partition means 512 MB for each partition.
So I lost at least 1 + 1 GB and 2 x 512 MB because I did not need the recovery and 2x data partitions. I rather would have separated the installation on 2 SD card, especially since my 2 raspberry pi 3 modells arrived this morning.
Now I have looked in the LINUX description of parted , but I am not sure,
* what device means in this case and
* if move ist the right command and
* if the end sector is always the startsector of the following paritition minus 1 (as from end partition 1 to start partition 2)?
Move seems to be a bit strange because I want to expand that partition and do not want to move that.
parted [options] [device [command [options...]...]]
for partition 7
sudo parted move /dev/mmcblk0p7 2490368 12132351
for partition 8
sudo parted move /dev/mmcblk0p8 12132352 15548415
Thx
P.S.: This try for partition 7 did not work - any suggestions?
Error: Could not stat device move - file or directory not found
Retry/Cancel?
Posted: Wed Mar 16, 2016 1:16 pm
by fruitoftheloom
Linux parted has a GUI version called gparted ;)
Posted: Wed Mar 16, 2016 4:45 pm
by typxxi
yeah, but that is not available in raspbian and I still have the same problem:#
How can I take use of the free space from the partition I have delete like "expand"?
Or is there a better way to merge or append a "second partitions" to the first?
Posted: Wed Mar 16, 2016 4:55 pm
by DirkS
typxxi wrote:yeah, but that is not available in raspbian and I still have the same problem:#
pi@raspi01:~$ apt-cache policy gparted
gparted:
  Installed: (none)
  Candidate: 0.19.0-2
  Version table:
     0.19.0-2 0
        500 http://mirrordirector.raspbian.org/raspbian/ jessie/main armhf Packages
pi@raspi01:~$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
Posted: Wed Mar 16, 2016 5:04 pm
by fruitoftheloom
gparted no available from Repository ???? Obviously you have issues beyond patitioning !!!!
Posted: Thu Mar 17, 2016 1:53 am
by typxxi
Hey,
I thought that i had to type in gparted at the command line. But that did not work and I thought that gparted was missing in raspbian and is just only part of linux. So I tried this:
gparted:
  Installiert:           (keine)
  Installationskandidat: 0.19.0-2
  Versionstabelle:
     0.19.0-2 0
That is the same as above. So how do I start gparted?
Meanwhile I was looking in fdisk commands and there is an expert option where I can change the sectors.
If I add up the sectors of the partition and the previous 512MB partitoin do I get an expanded partition ?
thx
P.S.: Now i installed gparted with sudo apt-get install gparted and found gparted in the gui - settings section. But I am unable to expand the partition even after reboot. I saved this report:
GParted 0.19.0 --enable-libparted-dmraid --enable-online-resize
libparted 3.2
/dev/mmcblk0p7 von 4.10 GiB auf 4.60 GiB vergrößern  00:00:00    ( FEHLER )
/dev/mmcblk0p7 kalibrieren  00:00:00    ( ERFOLG )
Pfad: /dev/mmcblk0p7
Anfang: 2490368
Ende: 11083773
Größe: 8593406 (4.10 GiB)
Dateisystem auf /dev/mmcblk0p7 auf Fehler überprüfen und (falls möglich) diese beheben  00:00:00    ( FEHLER )
e2fsck -f -y -v -C 0 /dev/mmcblk0p7
/dev/mmcblk0p7 ist eingehängt.
e2fsck 1.42.12 (29-Aug-2014)
e2fsck: Fortsetzung nicht möglich, wird abgebrochen.
Posted: Thu Mar 17, 2016 9:02 am
by DirkS
The messages don't give a lot of information, but it looks as if it doesn't want to run the filesystem check (ext2fsck) because the partition is mounted.
ATM I can only suggest to geet another SD card with e.g. Jessie, put the card in an SD card reader and run gparted that way.
Alternatively use a Linux live CD in another computer...
Posted: Thu Mar 17, 2016 11:09 am
by typxxi
Thanks, I will try that later when my new raspberry pi 3 has arrived. I hope that this will work.
My previous attempts under Windows 10 failed (MiniTool Paritition Wizard). But I hope that the raspi 3 should do that.
When I tried to delete the 512MB partition there was a warning that I first have to hang out the logical drives above partition 7 what I did. Then I was able to delete these 2 partitions.
Thx
Posted: Sun Mar 20, 2016 11:20 am
by typxxi
Thx, worked fine.
