Fuz
Problem with Librekinect for 360 Kinect on RPi2b
Mon Mar 14, 2016 5:18 am
I'm trying to install LibreKinect on my RPI2b, for an Xbox 360 Kinect. It's running Raspian "jessie". I have from Github, the unzipped Librekinect Master in my downloads folder. The "readme" seems to imply that I must compile a new kernel. Is this true, or can this be installed from what I have? Being an old curmudgeon and a Linux NOOB, I'm at an impasse.
In attempt to follow the instructions given for re-compile, it requires the kernel version. "uname -r" returns "4.1.13-V7+". With this plugged into the subsequent "wget..." command, "404 Not Found" is returned.
How/where can I proceed from here? Thanks for any assistance.
Nairod
Re: Problem with Librekinect for 360 Kinect on RPi2b
Sat Apr 02, 2016 8:33 am
Hi, i have done it using :
wget https://github.com/raspberrypi/linux/ar ... 1.y.tar.gz
Wish it will help U.
Fuz
Sat Apr 02, 2016 10:46 pm
Thanks Nairod! :)
I'll try this as soon as I can. Not sure how soon that will be. Whenever, I'll post result here. Thanks again.
