JAseng123
no such file or directory
Wed Feb 03, 2016 9:45 am
i've installed the following according to this post http://blog.rajenki.com/2015/05/alljoyn ... indows-10/
but i got this error " No such file or Directory"
now im stuck not sure what to do
can anyone help
Raspberry Pi 2
os:Raspain(NOOBS) linux
heres the result
RaTTuS
Contact: Twitter YouTube
Re: no such file or directory
Wed Feb 03, 2016 9:51 am
at what stage ?
I cannot read that image
either upload a decent one to imgur.com or paste the output to pastebin.com
or
sudo apt-get update && sudo apt-get install pastebinit
then pipe the output to pastebinit
whatever command | pastebinit
Covfefe
Navyscourge
Wed Feb 03, 2016 7:56 pm
I'm guessing from the output that shared library liballjoyn.so does not exist
Did the compile run without errors? Did you get the file ~/WORKING_DIRECTORY/alljoyn/core/alljoyn/build/linux/arm/debug/dist/cpp/lib/liballjoyn.so?
Did you create the link with... ?
sudo ln -sf ~/WORKING_DIRECTORY/alljoyn/core/alljoyn/build/linux/arm/debug/dist/cpp/lib/liballjoyn.so /lib/arm-linux-gnueabihf/liballjoyn.so
Did you get anything from this... ?
cd ~/WORKING_DIRECTORY/alljoyn/core/alljoyn/build/linux/arm/debug/dist/cpp/bin
ldd alljoyn-daemon
./alljoyn-daemon --version
JAseng123
Thu Feb 04, 2016 6:24 am
Navyscourge wrote:I'm guessing from the output that shared library liballjoyn.so does not exist
ldd alljoyn-daemon
"Did the compile run without errors? Did you get the file ~/WORKING_DIRECTORY/alljoyn/core/alljoyn/build/linux/arm/debug/dist/cpp/lib/liballjoyn.so?"
I set my working directory as this "alljoyn-15.09.00-src" which after ive downloaded from allseen alliance webpage, i've extracted and put in into the Desktop.(not sure if im correct)
"""Step 13: Open up the terminal and change directory to the desktop then to the source you have extracted in the above step using the cd command. E.g. cd Desktop/alljoyn-15.09.00-src
Step 14: Once it has successfully change directory into the source, we will now do the actual compilation, which can take some time. We will run this command first:
scons OS=linux CPU=arm WS=off OE_BASE=/usr BR=on BINDINGS=cpp CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf-"""
This was what i did next, after my~/working_directory/ it doesnt have "alljoyn" but instead many variations of "alljoyn_build etc"
"""""""""""""""" http://imgur.com/a/h2gcd """""""""""" i've uploaded it to imgur
