Atlas2016
Error on mvn exec:java help
Wed Oct 28, 2015 4:20 am
I'm trying to implement the new Alexa software Amazon released. Everything seems to work up until I execute the program, then it seems that Java starts up for a few seconds and then crashes. I get this core dump and I was hoping someone could give suggestions as to how I might get this working. I will also include the link to Amazon's guide as to how to implement this at the bottom if someone wants to try and run it and see if they get the same error.
# A fatal error has been detected by the Java Runtime Environment:
#  SIGILL (0x4) at pc=0x611f2b6c, pid=2143, tid=1669330016
# JRE version: Java(TM) SE Runtime Environment (8.0-b132) (build 1.8.0-b132)
# Java VM: Java HotSpot(TM) Client VM (25.0-b70 mixed mode linux-arm )
# Problematic frame:
# C  0x611f2b6c
# Core dump written. Default location: /home/pi/Alexa/samples/javaclient/core or core.2143
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread is native thread
siginfo:si_signo=SIGILL: si_errno=0, si_code=1 (ILL_ILLOPC), si_addr=0x611f2b6c
Registers:
  r0  = 0x611d5378
  r1  = 0x64500040
  r2  = 0x00000801
  r3  = 0x611c7720
  r4  = 0x00000030
  r5  = 0x637ff5ec
  r6  = 0x76ece198
  r7  = 0x637ff920
  r8  = 0x00000004
  r9  = 0x76ecc198
  r10 = 0x00000000
  fp  = 0x637ff4ec
  r12 = 0x00000007
  sp  = 0x637fee30
  lr  = 0x00000000
  pc  = 0x611f2b6c
  cpsr = 0x20000010
Top of Stack: (sp=0x637fee30)
0x637fee30:   76ecc198 637ff5e8 00000000 00000000
0x637fee40:   00000000 763030c4 00000152 763030c0
0x637fee50:   76304920 00000000 637fef9c 76eadea0
0x637fee60:   637ff678 637ff460 00000000 00000000
0x637fee70:   637ff4c8 00000000 763030c4 00000152
0x637fee80:   763030c0 76304920 00000000 637fef9c
0x637fee90:   14c6365c 0153065c 3f400000 41800000
0x637feea0:   00000000 00000000 00000000 00000000
Instructions: (pc=0x611f2b6c)
0x611f2b4c:   00000000 00000000 00000000 00000000
0x611f2b5c:   00000000 0000001b 76d3ebe8 00000000
0x611f2b6c:   76d3d8b8 611f2ba8 76f021e8 611f2bb0
0x611f2b7c:   76d3ebe8 0000001b 76f27d90 0000001b
Register to memory mapping:
  r0  = 0x611d5378
0x611d5378 is an unknown value
  r1  = 0x64500040
0x64500040 is an unknown value
  r2  = 0x00000801
0x00000801 is an unknown value
  r3  = 0x611c7720
0x611c7720 is an unknown value
  r4  = 0x00000030
0x00000030 is an unknown value
  r5  = 0x637ff5ec
0x637ff5ec is an unknown value
  r6  = 0x76ece198
0x76ece198: <offset 0x27198> in /lib/arm-linux-gnueabihf/libpthread.so.0 at 0x76ea7000
  r7  = 0x637ff920
0x637ff920 is an unknown value
  r8  = 0x00000004
0x00000004 is an unknown value
  r9  = 0x76ecc198
0x76ecc198: <offset 0x25198> in /lib/arm-linux-gnueabihf/libpthread.so.0 at 0x76ea7000
  r10 = 0x00000000
0x00000000 is an unknown value
  fp  = 0x637ff4ec
0x637ff4ec is an unknown value
  r12 = 0x00000007
0x00000007 is an unknown value
  sp  = 0x637fee30
0x637fee30 is an unknown value
  lr  = 0x00000000
  pc  = 0x611f2b6c
0x611f2b6c is an unknown value
Stack: [0x637b0000,0x63800000],  sp=0x637fee30,  free space=315k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  0x611f2b6c
Here is the link the the Reference Implementation that I have been following to work through this:https://developer.amazon.com/public/sol ... tion-guide . Any help what so ever would be very appreciated! Thanks! :D
jwenting
Re: Error on mvn exec:java help
Thu Oct 29, 2015 10:43 am
What you're getting is a JVM crash. I don't know what JVM comes preinstalled, probably an old version of OpenJDK.
Your best bet is to install the latest JDK directly from Oracle.
http://www.rpiblog.com/2014/03/installi ... ry-pi.html explains the process, but you'll need to change the commands a bit as the current version is 1.8.0_65-b17 (download URL: http://download.oracle.com/otn-pub/java ... flt.tar.gz ).
Atlas2016
Thu Oct 29, 2015 2:30 pm
Thank you very much, I'll try that.
