jannetta
PiFace problems
Sat Oct 10, 2015 10:07 am
Hi Folks
I have an old PiFace board running on my old Raspberry Pi. Everything used to work perfectly but I decided to format the SD card and update to the latest Raspbian and now I can't get the PiFace to work again. I followed the instructions on http://www.piface.org.uk/guides/Install ... _Software/ but when I run the test program I get the error message that says: no piface digital board detected.
I googled the error and tried a couple of things that were suggested but I can't get it working. Can someone perhaps help?
Regards
Jannetta
bulletmark
Re: PiFace problems
Sun Oct 11, 2015 11:18 pm
No one has answered so I'll offer this ..
I created a script to install the spidev stuff for the piface board which you could try. I have not tried it on Raspbian Jessie but it worked on Wheezy and it works on Arch which is now what I run with my Piface. Download it from https://raw.githubusercontent.com/bulle ... -spidev.sh and run it with sudo. Please let me know if it works and it not then show all the output here. Thanks.
KevinA
Re: PiFace problems
Fri Oct 30, 2015 6:27 pm
bulletmark wrote:No one has answered so I'll offer this ..
Doesn't work on Jessie, no longer uses backlist or spi_bcm2708 or modprobe I'm trying to find how to install spidev
bulletmark
Re: PiFace problems
Fri Oct 30, 2015 9:17 pm
KevinA wrote: Doesn't work on Jessie, no longer uses backlist or spi_bcm2708 or modprobe I'm trying to find how to install spidev
If it doesn't work can you please paste the script output here (in code tags). Thanks.
bulletmark
Re: PiFace problems
Sat Oct 31, 2015 2:48 am
Actually, I just installed the current Raspbian Jessie 2015-09-24-raspbian-jessie.img image to my RPi model 2 and apart from a single character typo I had in the script it works fine. I could read and write to my PiFace board.
I fixed the script and push the updated package to github and PyPI. I noticed stock Raspbian already has pip installed so anybody installing generic raspbian can just type the following to get their PiFace to work:
sudo pip install -U pifaceio
sudo install-spidev.sh
Then reboot. Sample test code:
#!/usr/bin/python
import pifaceio
pf = pifaceio.PiFace()
print "Inputs are {:#02x}".format(pf.read())
