cprins1908
mount network share on boot
Thu Aug 27, 2015 6:38 pm
Hi there,
I figured out how to mount a windows network share to my PI.
After that I added a line to my fstab so the mount is executed at each boot
Unfortunately my network file is not mounted during boot
When I type sudo mount -a at the command prompt my windows share is mounted so that means that the line in my fstab is correct.
Now I learned that this behavior might be caused by the fact the network is not active when fstab is being executed.
To overcome this adding a small script to /etc/init.d calling sudo mount -a (and a echo to so if its been executed) should be added to update-rc.d
(I wrote a similar script for starting VNC and that works)
When I boot my PI still the share is not mounted, I checked the boot log but no sign there from my echo I put in my script (I do see the echo from the VNC script).
What other options are there to mount my network share at boot time
Thanks in advance
Christian
Re: mount network share on boot
Thu Aug 27, 2015 7:05 pm
Put a mount command in /etc/rc.local.
There does seem to be a problem with mounting certain types of share at boot time, quite a few people have reported it. I think it might just be Windows type shares (CIFS/SAMBA), as I don't have any problems with my NFS file systems mounting at boot time.
Joe Schmoe
Thu Aug 27, 2015 7:07 pm
It also happens with USB drives (if for whatever reason, the USB subsystem isn't fully functional at the moment that fstab is processed).
beta-tester
Thu Aug 27, 2015 7:30 pm
Joe Schmoe wrote:It also happens with USB drives (if for whatever reason, the USB subsystem isn't fully functional at the moment that fstab is processed).
i think there was a bootdelay in cmdline.txt or config.txt needed for RPi2 to get some USB drives to be mounted properly at boot time via fstab.
BTW: i have a NAS that populates Windows shares only (no NFS)...
they will be mounted automatically at boot time via fstab (in case the share is available at boot time)
so, lucky me, in my case it works
//192.168.100.123/share /media/nas123 cifs defaults,uid=pi,gid=pi,user=guest,password=guest,rw 0 0
RPi B (rev1, 256MB), B (rev2, 512MB), B+, 2B, 3B, 3B+, ZeroW, ...
cprins1908
Thu Aug 27, 2015 7:45 pm
Adding sudo mount -a to the /etc/rc.local did the trick
typxxi
Tue Mar 22, 2016 8:05 pm
same problem here, but /etc/rc.local did not the trick or I made a mistake. I removed the first "#" and added the mount command that worked in the command line after boot.
!/bin/sh -e
sudo mount -t cifs -o user=ftpuser,password=123 //192.123.123.1/share /media/smbFNAS
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
Any suggestions?
thx
WOLF
JimmyN
Tue Mar 22, 2016 10:17 pm
Use systemd to mount it rather than rc.local, it works much better, those posts are a bit outdated.
Use the following in fstab (edit as needed of course)
//192.123.123.1/share /media/smbFNAS cifs username=ftpuser,password=123,uid=pi,gid=pi,x-systemd.automount 0 0
That's all one long line, no line breaks. I added the "uid" and "gid" so the mounted share would belong to "pi" rather than root. If you're using a different username on the RPi then use that instead of "pi".
typxxi
Tue Mar 29, 2016 3:40 pm
JimmyN wrote:Use systemd to mount it rather than rc.local, it works much better, those posts are a bit outdated.
I added that line to the fstab and made a reboot. If I try to change into that directory smbFNAS I got an error message like the following:
pi@Raspi2HBB:/media $ cd smbFNAS
di-bash: cd: smbFNAS: no "fitting" device "found/present"
Do I have to edit something else?
thx
WOLF
JimmyN
Tue Mar 29, 2016 4:01 pm
What do you get with a "df -h" command, or a "mount" command? Is the share mounted?
RaTTuS
Tue Mar 29, 2016 4:13 pm
typxxi wrote:Hello,
!/bin/sh -e
# rc.local
# value on error.
Any suggestions?
thx
put the # back in the first line of that file
then do it via systemd
Covfefe
typxxi
Tue Mar 29, 2016 5:56 pm
JimmyN wrote:What do you get with a "df -h" command, or a "mount" command? Is the share mounted?
As I mentioned before I got an error if I try to go into the "target dir" smbFNAS
If I do a mount manually I will be able to enter that dir and see all the subdirs of that NAStorage
Regarding your last questions df - h brings this
/dev/root 7,2G 4,8G 2,1G 70% /
devtmpfs 412M 0 412M 0% /dev
tmpfs 416M 0 416M 0% /dev/shm
tmpfs 416M 6,0M 410M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 416M 0 416M 0% /sys/fs/cgroup
/dev/mmcblk0p1 60M 20M 41M 34% /boot
tmpfs 84M 0 84M 0% /run/user/1000
There is no mounted NAS.
WOLF
typxxi
Tue Mar 29, 2016 8:45 pm
RaTTuS wrote:put the # back in the first line of that file
OK, I have put the # back and after reboot nothing has changed - no access
But what do you mean with that "via systemd"?
Even if I add that "systemd" to fstab I still get (after reboot) the same error if I try to change the directory.
If I try to go to "/media/smbFNAS" I still get the same error as mentioned above. And /media/smbFNAS does exist.
thx
WOLF
JimmyN
Tue Mar 29, 2016 8:51 pm
That's a bit unusual. First the error message itself when changing to the directory.
cd smbFNAS
Normally it would look like this:
cd smbFNAS
-bash: cd: smbFNAS: No such file or directory
And even if the mount had failed the /media/smbFNAS/ mount directory would be there, so you'd be able to "cd" to it, even though it's empty.
Do you have a mount directory at "/media/smbFNAS"?
What do you get with a "ls -l /media"
What is the exact mount command you're using that works (edit any passwords). After it's mounted manually what do you get with a "mount" command, and a "ls -l /media" command.
typxxi
Wed Mar 30, 2016 7:58 am
JimmyN wrote:That's a bit unusual. First the error message itself when changing to the directory.
cd smbFNAS
cd smbFNAS
maybe the raspbian translation into german is the source of that question because I have to translate it back. No such file or directory would mean in german "keine solche Datei oder Verzeichnis", but it was completly different
JimmyN wrote:And even if the mount had failed the /media/smbFNAS/ mount directory would be there, so you'd be able to "cd" to it, even though it's empty.
Yeah, that was the normal behaviour before I did these fstab and rc.local things.
JimmyN wrote:Do you have a mount directory at "/media/smbFNAS"?
That is what I want to and therefore I had created that smbFNAS directory.
JimmyN wrote:What do you get with a "ls -l /media"
pi@Raspi2HBB:~ $ ls -l /media
insgesamt 8
drwxr-xr-x 2 pi pi 4096 Mär 26 20:13 HDD1
drwxr-x---+ 2 root root 4096 Mär 20 17:51 pi
drwxr-xr-x 2 root root 0 Jan 1 1970 smbFNAS
JimmyN wrote:What is the exact mount command you're using that works (edit any passwords).
That one mentioned above and its parameters are identical to that of the mount command.
sudo mount -t cifs -o user=xxx,password=yyy //192.168.178.1/fritz.nas/ST310005-28AS-01 /media/smbFNAS
JimmyN wrote:After it's mounted manually what do you get with a "mount" command, and a "ls -l /media" command.
The same as mentioned above. But if I go into that smbFNAS directory I can see all the NAS files & directories. So it can mount, but only manually.
But this mount command only works if I do NOT have that "systemd.automount" line in my fstab (//192.123.123.1/share /media/smbFNAS cifs username=ftpuser,password=123,uid=pi,gid=pi,x-systemd.automount 0 0)
With that line in the fstab I even can not manually mount with the mount command because I would get an english error message (maybe not yet translated because normally I get german errors).
My raspbian installation was done around mid of march with only a few things added like ntfs support, samba, hp cups, MidnightCommander, a backup script and all the updates & upgrades and extended partition (from 4 to the whole 8 GB of that SANDISK SD Card)
thx
WOLF
JimmyN
Wed Mar 30, 2016 11:18 am
You're right, the different error message is probably a translation thing.
If you can mount it manually, then you can mount it with fstab. The only difference is timing, fstab runs during boot, where mounting it manually would be done after it's finished booting. The x-systemd.automount hands the mount to systemd which will wait to mount the drive until it's first accessed, so you're assured everything is up and running at that point.
If you're mounting it manually using "sudo mount -t cifs -o user=xxx,password=yyy //192.168.178.1/fritz.nas/ST310005-28AS-01 /media/smbFNAS" then don't use the systemd.automount.
Let's check some things.
Use this in fstab
//192.168.178.1/fritz.nas/ST310005-28AS-01 /media/smbFNAS cifs user=xxx,password=yyy,uid=pi,gid=pi,x-systemd.automount 0 0
Reboot and check dmesg to see what systemd has to say.
dmesg | grep mount
This pi is mounting three network shares, yours may read a little different due to translation, but you can see that systemd has set up all the automounts.
 dmesg | grep mount
[    3.866626] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (nul        l)
[    3.932557] devtmpfs: mounted
[    5.564148] systemd[1]: Starting home-jimmy-Win7\x2dFolder.automount.
[    5.622608] systemd[1]: Set up automount home-jimmy-Win7\x2dFolder.automount.
[    5.644737] systemd[1]: Starting home-jimmy-NAS.automount.
[    5.670071] systemd[1]: Set up automount home-jimmy-NAS.automount.
[    5.689924] systemd[1]: Starting home-jimmy-Network\x2dfolder.automount.
[    5.718175] systemd[1]: Set up automount home-jimmy-Network\x2dfolder.automount.
[    5.741117] systemd[1]: Starting Arbitrary Executable File Formats File System Automou        nt Point.
[    5.773394] systemd[1]: Set up automount Arbitrary Executable File Formats File System        Automount Point.
Now try a "df -h" command to see it the mount is listed. If it's not then try using a "sudo mount -a" command, and then another "df -h" to see if that mounted it.
typxxi
Wed Mar 30, 2016 6:16 pm
Hey Jimmy,
now everything works and I found the source of this misery.
But step by step: Here are my results after I appended the line in fstab you recommended.
pi@Raspi2HBB:~ $ dmesg | grep mount
[    2.115018] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.138444] devtmpfs: mounted
[    3.671675] systemd[1]: Starting media-smbFNAS.automount.
[    3.702997] systemd[1]: Set up automount media-smbFNAS.automount.
[    3.739522] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    3.759152] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.076840] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   10.747545] CIFS VFS: cifs_mount failed w/return code = -101
[   10.839224] CIFS VFS: cifs_mount failed w/return code = -101
2nd step
pi@Raspi2HBB:~ $ df -h
Dateisystem                                Größe Benutzt Verf. Verw% Eingehängt auf
//192.168.178.1/fritz.nas/ST310005-28AS-01  2,0T     84G  1,9T    5% /media/smbFNAS
3rd step
pi@Raspi2HBB:~ $ sudo mount -a
mount error(16): Device or resource busy
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
I must admit that I first did all what you asked for and copied it - without thinking.
Later I looked into the results and recogniced that the NAS HDD must have been connected because the data regarding that NAS HDD were right!
Then I did a reboot and everything was there where it should be.
But to be honest: I really do not know, what the trick was to make it happen.
Therefore I will remove all the other things which might have been changed and are no longer needed like that rc.local stuff.
Meanwhile I removed the rc.local stuff and it still works.
I asked myself what went wrong and it could be that all my problems were the result of a tiny difference: a result of a copy and paste action from another web page I assume
And you also used the fstab commandline in 2 different syntax
username=123
user=123
Username does not work - at least in fstab, but user does work.
That I found out when I checked my "Ras Pi Master Setup Recipe" from where the hell I got all these problems because at the beginning of easter saturday everything worked fine until I came across this site while I was trying to establish a guest / user share mode. It was late a night when my pi suddenly did not reboot and the next morning I had forgotten what I had exactly changed at last, the changes of my previously working "mount line" in fstab were gone because I forget to use # and deleted that line that had been working before:
https://rasspberrypi.wordpress.com/2012 ... pberry-pi/
There you will find these lines:
2.1 Guest Share
sudo mount -t cifs -o guest //WindowsPC/share1 /mnt/mountfoldername
Tip: If your share has space then run the following command, notice the quotes
sudo mount -t cifs -o guest "//WindowsPC/Share 1" /mnt/mountfoldername
2.2 Password Protected Share
sudo mount -t cifs -o username=yourusername,password=yourpassword //WindowsPC/share1 /mnt/mountfoldername
And I can tell you that you can kill your Ras Pi Installation if fstab content is wrong. At least 3 or 4 times I had to reinstall the whole thing ... and reboot .
Many, many thanks for your constant support the last few days. :D
WOLF
JimmyN
Wed Mar 30, 2016 7:47 pm
You're welcome, glad you got it working. Copy/Paste will mess you up sometimes. You grab an extra quote mark or space, or leave a bit behind when you copy, and it's usually those kind of little things that hang you up and are hard to find.
I think I got the "user" from the line you posted, since I didn't know if your HDD setup needed "username" or "user" to log in. I did add "uid" and "gid" to the line so the mounted files would belong to "pi".
The errors you see in dmesg (they also show up on the boot screen and syslog)
are from fstab trying to mount the share during boot, even though systemd will be mounting it later. You can suppress those errors by adding ",noauto" in front of the ",x-systemd.automount". With "noauto" fstab won't try to mount it when booting, so you won't get the error messages, but it also prevents you from mounting it from the commandline using "sudo mount -a" since you've disabled the auto mount function.
voyager529
Thu Mar 08, 2018 7:17 pm
Hey everyone!
Sorry-not-sorry for resurrecting an old thread. I'm trying to do this same thing, and I'm almost there.
I have a folder share on my DD-WRT router I want my RasPi to be able to utilize. Here is the relevant code in my /etc/fstab:
//192.168.2.1/media  /media/media       cifs username=[snip],password=[snip],nofail,x-systemd.automount,x-systemd.requires=network-online.target,x-systemd.device-timeout=1  0
When I use my Windows laptop on the share, everything looks and works exactly the way it's supposed to. When I use the Pi, I can see it, and I can read from it. However, when I do things like "ls >/media/media/testfile.txt", it will create a zero-byte file, but can't write actual data to it. Furthermore, I can delete files from those shares, which I would assume requires write access.
Now, my gut feeling is that this is a permissions issue. Well, DD-WRT has the share set to read/write, and I set the chmod on the folders to 777, and again, Windows works fine. I know this is more of a general Linux question, but I appreciate whatever assistance can be provided.
Thank you!
Fri Mar 09, 2018 12:57 pm
Change
to
credentials=/root/.cifsuser,
Create a /root/.cifsuser file with
username=[[snip]]
password=[[snip]]
With the password enclosed in brackets. That's more secure, you can use sudo chmod 600 /root/.cifsuser to protect your secrets.
Also add
uid=pi,group=pi
to your mount options string as that means the share will be owned by the pi user and not by root. That gives pi complete control over the share (based on what your .cifsuser credentials allow).
This is a doctor free zone.
kent.lucas.11
Fri Jul 13, 2018 3:32 am
I'm still having issues with this and I followed the instructions above adequately, I believe. I may be missing something.
This is my line in my fstab:
//10.1.2.1/USB_Storage /mnt/lucas cifs username=xxx,password=yyy,uid=pi,gid=pi,x-systemd.automount 0 0
And below is the result of a dmesg | grep mount.
pi@raspberrypi:/mnt/lucas $ dmesg | grep mount
[    1.010774] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.020683] devtmpfs: mounted
[    2.177955] systemd[1]: Set up automount mnt-lucas.automount.
[    2.898760] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[  214.027164] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) speci                                                fy vers=1.0 on mount.
[  215.085099] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) speci                                                 fy vers=1.0 on mount.
When I manually mount the share, it works fine. When I run sudo mount -a after rebooting, it also mounts fine, but does give me the error message below.
pi@raspberrypi:~ $ sudo mount -a
Anything I'm missing? Like I said, it will mount fine when I do a sudo mount -a, so the line in fstab must be right. Thank you for your time.
stefano.ferroni
Wed Dec 26, 2018 10:21 pm
Well Lucas, I hope you have solved your problem by now.
Anyway:
1. the "dialect" line can be avoided by specifying a newer version (I put vers=3.0 in the options)
2. the "device or resource busy" are probably due to the gid=pid, uid=pi options. You don't need to get rid of them.
3. everything has started to work fine when I have set the Raspberry to wait for network on boot.
