mirrordirector.raspbian.org
Posted: Sun Aug 16, 2015 1:01 pm
by elatllat
nice apt-get update
Err http://mirrordirector.raspbian.org wheezy Release.gpg
  Could not connect to mirrordirector.raspbian.org:80 (5.153.225.207), connection timed out
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/Release.gpg  Could not connect to mirrordirector.raspbian.org:80 (5.153.225.207), connection timed out
host mirrordirector.raspbian.org
mirrordirector.raspbian.org has address 5.153.225.207
mirrordirector.raspbian.org has IPv6 address 2001:41c9:1:3ce::11
traceroute mirrordirector.raspbian.org
 4  64.71.240.1 (64.71.240.1)  14.884 ms  18.638 ms  18.378 ms
 5  xe-0-0-3.cr1.tor2.ca.as4436.gtt.net (69.31.143.129)  16.714 ms  16.456 ms  16.200 ms
 6  xe-2-1-0.tor11.ip4.gtt.net (89.149.185.201)  15.682 ms  13.312 ms  14.944 ms
 7  xe-8-0-0.man11.ip4.gtt.net (141.136.105.174)  111.246 ms  125.741 ms  125.511 ms
 8  te4-5-201.cr1.man.bytemark.co.uk (141.136.98.238)  277.193 ms  109.219 ms  108.900 ms
 9  te0-1.cr1.lds.bytemark.co.uk (91.223.58.69)  99.902 ms  99.409 ms  99.339 ms
10  te1-6.cr1.yrk.bytemark.co.uk (91.223.58.76)  99.578 ms  99.134 ms  98.725 ms
11  po1.ar1.dc1.yo26.yrk.bytemark.co.uk (91.223.58.29)  97.491 ms  99.808 ms  99.554 ms
12  * * *
30  * * *
curl -v http://mirrordirector.raspbian.org/raspbian/dists/wheezy/Release.gpg > /dev/null
* About to connect() to mirrordirector.raspbian.org port 80 (#0)
*   Trying 5.153.225.207...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:02:07 --:--:--     0* Connection timed out
* couldn't connect to host
* Closing connection #0
curl: (7) couldn't connect to host
Re: mirrordirector.raspbian.org
Posted: Sun Aug 16, 2015 1:06 pm
by kusti8
Down for me also.
Probably doing some maintenance.
http://www.isitdownrightnow.com/mirrord ... n.org.html
Posted: Sun Aug 16, 2015 1:12 pm
by elatllat
Posted: Sun Aug 16, 2015 1:13 pm
by GordonTGopher
Down in need of maintenance; https://twitter.com/plugwash/status/632894123163435008
Gordon
Posted: Sun Aug 16, 2015 1:24 pm
by elatllat
Found a working mirror;
http://raspberrypi.stackexchange.com/a/32408
might be time raspbian got a backup server.
Posted: Sun Aug 16, 2015 2:08 pm
by plugwash
We have issues with the raid array, someone from bytemark support is onsite at the datacenter investigating it at the moment.
I agree on the backup server, i've tried to arrange one in the past but not got anything to actually happen. Anyone out there fancy donating a server with a few terrabytes of diskspace and a gigabit internet connection for use as a warm spare?
Posted: Sun Aug 16, 2015 3:10 pm
by plugwash
ok, Bytemark replaced the write cache module in the server's raid controller and got the server back up. They also advised me that there may be failed drives in the array and I should check with hpacucli. Unfortunately while I was doing so the server crashed again (I suspect the two are related but I don't know for sure).
Bytemark are continuing to investigate.
Posted: Sun Aug 16, 2015 3:12 pm
by MacNastard
Any Idea when it will be running, I'm busy setting up for the first time and couldn't get any installs working.
Posted: Sun Aug 16, 2015 3:28 pm
by HotRod
Seems like it's up again.
Good work :)
Posted: Sun Aug 16, 2015 3:43 pm
by plugwash
yeah, it's up again now, apparently in addition to the write cache card failure we also had a drive failure. The drive has been replaced and the array is now rebuilding.
Posted: Sun Aug 16, 2015 3:58 pm
by bla
Thanks for your support plugwash!
Posted: Sun Aug 16, 2015 10:18 pm
by giova
Thank you for your prompt fix (hard sunday :D )
Posted: Fri Nov 20, 2015 5:55 am
by roboneo
hi, its the server down again? i need to install python-webpy and i dont know what else i could do
Posted: Sat Nov 21, 2015 12:40 pm
by plugwash
Right now the server is up but it seems to have been suffering some serious hardware instability recently
