saj
ERROR: could not insert 'spi_bcm2708': No such device
Wed Mar 25, 2015 6:07 pm
I have been trying to enable SPI on the latest Pi 2. Each time I run ' sudo raspi-config' and enable the SPI and then exit the response is 'ERROR: could not insert 'spi_bcm2708': No such device.
pi@sajpi ~ $ sudo raspi-config
I cannot understand why this keeps happening ? Help please !!
SH
joan
Re: ERROR: could not insert 'spi_bcm2708': No such device
Wed Mar 25, 2015 7:09 pm
It may be a device tree related problem.
Add dtparam=spi=on to /boot/config.txt and reboot.
See http://www.raspberrypi.org/forums/viewt ... 28&t=97314 for full details.
saj
Wed Mar 25, 2015 7:48 pm
Hi,.
I have done that - but still no luck I have even used the raspi-config to enable SPI/DT/kernel etc.
Regards,
SH
joan
Wed Mar 25, 2015 7:51 pm
uname -a
cat /etc/os-release
cat /proc/cpuinfo
saj
Wed Mar 25, 2015 11:25 pm
Hi.
I am away from the office at the moment but a quick question:
I understand running those commands will return system info. But what information will they give regarding the issue I'm having with SPI.
Regards.
Saj
saj
Thu Mar 26, 2015 1:01 pm
Below are the responses from the commands :
I notice that the Hardware is BCM2709 not BCM2708 ??
uname -a
Linux sajpi 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : BCM2709
Revision : a01041
Serial : 000000001d74c68d
Regards,
SH
Thu Mar 26, 2015 1:08 pm
saj wrote:Hi,.
Regards,
SH
Have you added it to the right config?
Boot while holding the [SHIFT] key. Use the NOOBS recovery system to edit your config.txt file.
This is a doctor free zone.
joan
Thu Mar 26, 2015 1:16 pm
As it happens they don't help much. I wanted to confirm you had a Pi2, although in actual fact that is pretty irrelevant to the SPI problem as well.
Does
lsmod | grep spi
show the module as loaded?
Is the modules present at /lib/modules/3.18.7-v7+/kernel/drivers/spi/spi-bcm2708.ko
I don't remember any problems but perhaps you might as well update to the latest firmware with
sudo rpi-update
saj
Thu Mar 26, 2015 2:15 pm
Thanks for the help.
lsmod | grep spi does not return anything.
spi-bcm2708.ko is in /lib/modules/3.18.7-v7+/kernel/drivers/spi
I'll try the update now
Regards,
SH
saj
Thu Mar 26, 2015 2:24 pm
Hi ,
I believe I tried sudo rpi-update yesterday and it killed the Pi. It would get stuck on reboot and hang. I dont want to re-run this command again if there is an issue.
From what I read the standard update should take care of the firmware.
Any thoughts ?
saj
Thu Mar 26, 2015 3:22 pm
Just ran rpi-update and it kills the pi on boot up again:
Download from here : http://expirebox.com/download/b6939714a ... 84e85.html
Thu Mar 26, 2015 3:35 pm
Try this
sudo apt-get --reinstall install raspberrypi-bootloader
that will re-install the stock stable kernel and /lib stuff.
saj
Thu Mar 26, 2015 3:37 pm
I have to re-flash the sd card - i cannot do anything with the system, it is completely stuck
I have seen this : http://www.raspberrypi.org/forums/viewt ... 78#p206778
saj
Thu Mar 26, 2015 3:48 pm
Is that another way to update the pi to the latest firwamre/libs etc ?
Thu Mar 26, 2015 3:55 pm
saj wrote:Is that another way to update the pi to the latest firwamre/libs etc ?
Clone stuff from another SDCard (your RPi booted from one card with the other mounted in a USB reader).
It lives in partitions #1 & #5 and in /lib/modules on the root filesystem.
saj
Thu Mar 26, 2015 3:59 pm
How do I get to the problematic SD card on a second pi ? I have plugged it in. What commands do i need to run from the shell ?
In simple in layman's terms would be most appreciated !!
2. After running these command will I get the pi up and running with spi support ?
Regards,
joan
Thu Mar 26, 2015 4:30 pm
It would be easier if you are using a non-Pi, as the Pi will be confused if you swap out its SD card.
Either another Linux box or a Pi with a USB SD card reader module.
Are you using NOOBS or Raspbian?
No, this won't make SPI work, we still don't understand what is wrong.
saj
Thu Mar 26, 2015 4:42 pm
This is the Pi 2 I have: http://www.element14.com/community/comm ... spberrypi2
Its is NOOBS.
I have another Pi I can use, what do I need to do in order to get the SD card (crashing after running rpi-update) back up and running?
What are the command needed to run ?
Regards,
SH
joan
Thu Mar 26, 2015 5:12 pm
I can't help with NOOBS. I don't know how it works.
saj
Thu Mar 26, 2015 5:34 pm
Is this something to do with the board/hardware I have? Or maybe an issue with a batch of boards? Many others have SPI etc working. NOOBS is the preferred method for simplicity.
saj
Thu Mar 26, 2015 6:12 pm
I will move away from NOOBS and install Raspbian now and try again.
saj
Thu Mar 26, 2015 7:04 pm
Good news, I have finally got the SPI devices listen in /dev . So now I am there.
The solution - dont use NOOBS !!! I reformatted the SD Card installed the Raspbian image from the Pi website and updated everything - worked first time as it should !!
Don't know what NOOBS is doing ???!!!
Next to write some code and test the SPI.
Regards,
Saj
Dimonira
Thu Jul 23, 2015 8:55 pm
Hi!
Help please!
I have the same problem in my RPi 2 (see attached pic), raspbian 4.0.8-v7+ #805. But I have not used NOOBS.
The name of the module is written with an underscore spi_bcm2708, but file name is written with a hyphen spi-bcm2708. Is it right?
screenshot
joan
Thu Jul 23, 2015 9:09 pm
Dimonira wrote:Hi!
Help please!
The underscore and hyphen are synonyms for the module load command.
The SPI module is now spi_bcm2835.
Use the following command to load the module.
sudo modprobe spi_bcm2835
However you should be using device tree in which case the module should be loaded automatically.
Add the following line to /boot/config.txt and reboot.
dtparam=spi=on
Dimonira
Thu Jul 23, 2015 9:19 pm
joan wrote: The SPI module is now spi_bcm2835.
This command is executed without error.
joan wrote: However you should be using device tree in which case the module should be loaded automatically.
dtparam=spi=on
This line is already present.
Does this mean that everything is OK? How to check?
