Cole1717
Re: Python GPIO does not work on Raspberry Pi 2
Thu Jun 04, 2015 12:40 pm
When i booted the pi for the first time, i went through all the settings just to see what was there. I think it was disabled, or maybe I read somewhere that you don't need it.
Rozalija
Sun Nov 22, 2015 3:57 pm
joan wrote:
Cole1717 wrote:I'm fairly certain I left that disabled because I didn't know what it was. What is it exactly? I'll definitely try enabling it.
It's something you have to be using if you want to use RPi.GPIO.
I'm not competent to explain its purpose.
If your /boot/config.txt contains a line such as the following then remove it.
device_tree=
I have the sameproblem and it is solved by this solution. However, I'm also going to use I2C which needs that line to be in config.txt as stated here. Could you please give me some hints how can I have both at the same time?
joan
Sun Nov 22, 2015 5:27 pm
@yugi_oh
You should be using device tree now. It should now work.
Rozalija
Sun Nov 22, 2015 5:41 pm
joan wrote:@yugi_oh
Thank you for your post. But when I remove the "device_tree=", the i2c stops working and "i2cdetect -y 1" raise the error :
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
In case I uncomment the "device_tree=", it works correctly. any idea?
joan
Sun Nov 22, 2015 5:49 pm
yugi_oh wrote:
joan wrote:@yugi_oh
You should not have a line in /boot/config.txt which says
device_tree=
You should have a line in /boot/config.txt which says
dtparam=i2c_arm=on
You should have a line in /etc/modules which says
i2c-dev
Rozalija
Sun Nov 22, 2015 5:57 pm
joan wrote:
yugi_oh wrote:
joan wrote:@yugi_oh
device_tree=
dtparam=i2c_arm=on
i2c-dev
Thanks a lot ! worked like a charm
