CUPS driver HP Pro 200
Posted: Sat Feb 28, 2015 3:23 am
by liderbug
I'm trying to get a HP Pro 200 color MFP M276nw working. I fire up CUPS but when I get to the Select driver section it's not there.
Help!!!
Please
cal
Re: CUPS driver HP Pro 200
Posted: Sat Feb 28, 2015 6:45 am
by fruitoftheloom
liderbug wrote:I'm trying to get a HP Pro 200 color MFP M276nw working. I fire up CUPS but when I get to the Select driver section it's not there.
Help!!!
Please
cal
There have been updates to Raspbian including CUPS so:
sudo apt-get update
sudo apt-get dist-upgrade
If CUPS still does not show the HP LaserJet Pro 200 color MFP M276nw you will need to install a newer version of HPLIP than is supplied with Raspbian Wheezy, "Download HPLIP" from
http://hplipopensource.com/hplip-web/mo ... 276nw.html
Use the "The HPLIP Automatic Installer"
Posted: Sun Mar 06, 2016 11:29 pm
by typxxi
Hey,
I have downloaded the hplip-3.16.2.run file
I copied it to the /home/pi diretory and switched into that directory
this seems to work (sh hplip-3.16.2.run)
until I was asked for a superuser / root password, which I do not have.
What do I have to do now?
Posted: Mon Mar 07, 2016 8:08 am
by fruitoftheloom
typxxi wrote:Hey,
Did you give yourself permissions ?
sudo usermod -a -G lpadmin pi
pi is the default user of Raspbian !
