healingeye
Ubuntu 19
Sun Oct 20, 2019 12:05 am
Can we get Ubuntu 19.10 to show up in our Raspberry Pi recovery mode so we can install it through n00bs?
I am just wondering if it is possible, thanks for the help! :P
B.Goode
Re: Ubuntu 19
Sun Oct 20, 2019 6:39 am
If the Operating System can be run on your RPi it can, in principle, be added to your copy of the NOOBS Installer. Note the recent thread documenting difficulties running this OS on an RPi 4 board. Ref: https://www.raspberrypi.org/forums/view ... 9#p1553547
Documentation for adding a custom OS to NOOBS here - https://github.com/raspberrypi/noobs/bl ... os-version
Or see the PINN alternative, actively developed and maintained by a contributing member of these forums - https://github.com/procount/pinn/blob/m ... ME_PINN.md
procount
Re: Ubuntu 19
Sun Oct 20, 2019 8:04 am
I did have a quick go at converting this for PINN, but it uses UBOOT, so it needs a little more massaging to work. And given the issues mentioned above, I decided to leave it a while until it is more proven.
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
BRX7
Re: Ubuntu 19
Sat Nov 09, 2019 10:22 am
Ive extracted boot and root folders onto the empty project spaces, I wonder if anyone has had it running yet with pinn/noobs
latest official image http://cdimage.ubuntu.com/releases/19.1 ... pi3.img.xz
boot sequence section mentions different bootloader
https://wiki.ubuntu.com/ARM/RaspberryPi#Installation
procount
Re: Ubuntu 19
Sat Nov 09, 2019 1:41 pm
Go with the alternative bootloader of replacing UBOOT with the standard Raspberry pi bootloader (Uboot does not like to live on other partitions).
See my conversion notes at https://github.com/procount/pinn/wiki/H ... using-PINN
Also see https://github.com/procount/pinn/blob/m ... os-version
Ubuntu 19.10 uses partition labels to mount its partitions, rather than PARTUUIDs or /dev/xxx. This means you can only install 1 copy of the OS on your target drive.
If you manage to convert it I'll be glad to host it.
Return to “Ubuntu”
