boomhaueruk
Touchscreen no display with Raspberry Pi 3 B
Sun Dec 09, 2018 12:24 am
I cannot get my official touchscreen working with a Raspberry pi 3 b.
As pictured here;
https://www.raspberrypi.org/products/ra ... 3-model-b/
I've got the latest version of Raspbian, have tried powering both screen and pi with seperate power, have tried it with GPIO power pass through, nothing works, at no time do I get a display on the touchscreen.
If I plug an HDMI cable in the Pi is booting - though it constantly shows the 'high temperature' logo in the top right. It also seems to go on the internet ok to download upgrades (I've done sudo apt-get update, sudo apt-get upgrade and sudo rpi-update and they seem to connect ok) but the browser won't.
I've tried adding "ignore_lcd=0" to the end of config.txt - it seemed to come up from time to time - but that hasn't made a difference.
I've plugged my other Pi - a 3 B+ - in to the screen and that works just fine with the ribbon cable and seperate power supplies, so I know the display is ok.
I know I'm meant to do "dmesg | grep -i FT5406" or something, (I've read this viewtopic.php?t=122891) but I think I've reached the end of my knowledge, it's getting into long lines I can't recreate - (Incidentally I'm not 100% on how to type a | symbol?) - so could do with some help.
Is the Pi itself buggered perhaps?
DirkS
Re: Touchscreen no display with Raspberry Pi 3 B
Sun Dec 09, 2018 10:56 am
Are you sure you're seeing the high temperature icon?
https://www.raspberrypi.org/documentati ... g-icons.md
boomhaueruk
Sat Dec 15, 2018 12:20 am
Yes, I believe so.
Took a photo of it for you. That's immediately after boot
Tue Dec 18, 2018 2:48 pm
boomhaueruk wrote:
Tue Dec 18, 2018 2:34 pm
Any help?
Firstly if it is overheating have you previously damaged your RPi SBC ??
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
boomhaueruk
Tue Dec 18, 2018 8:02 pm
The pi was working fine as far as I knew. It's been running Kano.
boomhaueruk
What's an sbc? How would I know if it was damaged?
