aneira92
Turn on the screen when the raspberry is on
Wed Nov 07, 2018 8:14 pm
I have a raspberry with the touch screen and when I disconnect the power of the screen goes off (it is expected), but when the power is turned on again, it does not turn on. It only turns on when you turn on raspberry and screen at the same time.
I need to be able to turn the screen on and off without needing to restart the raspberry
6by9
Re: Turn on the screen when the raspberry is on
Thu Nov 08, 2018 10:19 am
The screen is not designed to be hot-pluggable or switched independently of the Pi. It requires a startup sequence to be sent to it by the Pi, and that only happens during boot
You can control the backlight (which is most of the power consumption) from the Pi.
echo 0 > /sys/class/backlight/rpi_backlight/brightness
0 is the brightness value in this example. Values between 0 (off) and 255 (max brightness) are permitted. It may need to be run as root.
