Scheduled brightness on pi 3b+/RPi Display
Posted: Thu Oct 04, 2018 5:20 pm
by Bikce
Is there any script that will change the brightness of the raspberry display during set hours. For example I want the screen to be full brightness until 4:00 PM. Then it stays around 40-50% percent brightness until 5:00 AM. Appreciate your answers :D
Re: Scheduled brightness on pi 3b+/RPi Display
Posted: Thu Oct 04, 2018 6:20 pm
by DougieLawson
I use sunwait to determine when daylight starts/ends and drive the RPF display brightness with a script when sunwait ends.
45 4 * * * /usr/local/bin/sunwait civ up +0:00:00 51.2N 1.13W ; /usr/local/bin/sunny.sh light;
30 15 * * * /usr/local/bin/sunwait civ down -0:00:00 51.2N 1.13W ; /usr/local/bin/sunny.sh dark;
#!/bin/bash
NOW=$(TZ=Europe/London date '+%T %d/%m')
if [ "$1" == "reboot" ]; then
  if [ ! -f /var/run/lightordark ];
  then
    echo $1' @ '$NOW > /var/run/lightordark
  fi
  else
fi
if [ "$1" == "light" ]; then
  /usr/local/bin/gpio -g pwm 18 0
  echo "128" > /sys/devices/platform/rpi_backlight/backlight
else
  /usr/local/bin/gpio -g pwm 18 1023
  echo "255" > /sys/devices/platform/rpi_backlight/backlight
fi
Posted: Fri Oct 05, 2018 1:19 am
by W. H. Heydt
I do it with set times on my "alarm colck", and like Mr. Lawson, use cron to control it:
# Evening Dim Display
00 22 * * * echo 16 > /sys/class/backlight/rpi_backlight/brightness
# Normal weekday
40 05 * * 1-5 echo 250 > /sys/class/backlight/rpi_backlight/brightness
# No school weekday
# 20 07 * * 1-5 echo 250 > /sys/class/backlight/rpi_backlight/brightness
# Normal Saturday
50 07 * * 6 echo 250 > /sys/class/backlight/rpi_backlight/brightness
# Normal Sunday
50 06 * * 7 echo 250 > /sys/class/backlight/rpi_backlight/brightness
My alarm clock is a Pi2Bv1.1, but this sort of thing is generally independent of the model of Pi being used.
Posted: Wed Oct 10, 2018 3:21 pm
by Bikce
# Normal weekday
# No school weekday
# Normal Saturday
# Normal Sunday
Thanks!
This was what I was looking for !! :D
