uniu
Official Raspberry 7" screen problem - vertical colored lines only
Sat Jun 16, 2018 9:30 am
Hi Everyone!
I try to use my old touch screen again, without any success. It worked well for 2 years ago.
I tried with other Pi and other cable also, but i have got the following vertical colored lines picture:
The ribbon cables are well sealed.
This is what is see:
https://drive.google.com/file/d/1iHX8Fy ... sp=sharing
Detailes:
Official 7" Pi touchscreen v1.1
Raspberry Pi3 B v1.2
Noobs Version: 2.8.1 and Raspian Stretch 4.14 (I tried both of them)
Does anyone have any idea?
Thanks in advance!
Re: Official Raspberry 7" screen problem - vertical colored lines only
Sat Jun 16, 2018 9:51 am
Pull the green and yellow wires off.
This is a doctor free zone.
uniu
Sat Jun 16, 2018 12:24 pm
Thank You for your answer!
But I connected the GND and +5V only...
Beside of that I tried with USB cable without any success.
Sat Jun 16, 2018 12:40 pm
Pull the ribbon cable, re-fit and retest.
If that doesn't work, replace the ribbon cable.
gkaiseril
Sat Jun 16, 2018 4:38 pm
With 2 power supplies or a Y adapter one can avoid the jumper wires. Also make sure there no broken or lifted pads on the ribon and the ribon is straight in the socket.
I have used the 7" touch screen with many version of the pi with no issue. It might not work a non-raspbian os
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
uniu
Sun Jun 17, 2018 9:00 am
Thanks for everybody!
But as I wrote I tested with an other ribbon cable (it seems for me the camera cable and the dsi cable the same, so I change it for a camera cable) without any success. :( And I resealed of many times.
Do you know somebody how I replace the LCD driver board for a new one ? Maybe this will be the cheapest solution to continue the troubleshooting.
Sun Jun 17, 2018 9:02 am
There are no parts available for the 7" display. Your only choice is a complete new display.
gkaiseril
Sat Jun 23, 2018 6:16 pm
Make sure you are not shorting out any of the GPIO pins or any points on the bottom of the Pi.
uniu
Fri Oct 05, 2018 6:15 pm
Hi All.
Finaly I found the problem.
The driver board was broken.
But I successfully replaced by a not official driver board.
This is the driver board (I bought without LCD screen)
https://www.aliexpress.com/item/New-7-i ... 4c4dZictxI
aBUGSworstnightmare
Fri Oct 05, 2018 6:33 pm
Hi All.
would be interested to see how this connects to DSI interface and your touch
Return to “Official Foundation Display”
