Bill WA9BA
Hook-up 7" touch screed
Fri Jun 03, 2016 12:39 pm
I am new to the PI.
I bought a 7" touchscreen display and am confused about hooking it to the PI.
The ribbon cable I understand, but the extra 4 wires have me confused, what are they for?
Bill
Laurens-wuyts
Re: Hook-up 7" touch screed
Fri Jun 03, 2016 12:44 pm
These are to connect the I²C from the display to the pi if you have an older pi.
You do have to connect the 5V and GND wire from the display to pin 2 and 6 of the raspberry pi.
Laurens
alphanumeric
Fri Jun 03, 2016 1:44 pm
If you power it via the micro USB port, you don't need to use any of those jumper wires. ;)
6by9
Fri Jun 03, 2016 1:50 pm
alphanumeric wrote:If you power it via the micro USB port, you don't need to use any of those jumper wires. ;)
Unless you want to power your Pi via the display to save a power supply.
alphanumeric
Fri Jun 03, 2016 2:01 pm
Yes, lots of ways to do it. I could have worded my post better. I was trying to say, you don't have to use them, they are optional depending on what you have on hand. I have a ribbon cable/cobbler hooked up to my Pi. No easy way to use those jumpers with that setup. My Pi and display are each feed power via their micro USB ports. I use common 5V 10A power pack though.
tsaG
Fri Jun 03, 2016 2:25 pm
And what about the touch screen? This is also handled when connecting it over USB? ;)
Laurens-wuyts
Fri Jun 03, 2016 2:29 pm
tsaG wrote:And what about the touch screen? This is also handled when connecting it over USB? ;)
I think the touchscreen goes over the DSI connector :? (Not sure though)
Laurens
6by9
Fri Jun 03, 2016 2:30 pm
Correct.
alphanumeric
Fri Jun 03, 2016 3:03 pm
Yes, the touch panel part also goes over the DSI. The USB is for power only.
Laurens-wuyts
Fri Jun 03, 2016 3:05 pm
Correct.
Noted :D
Laurens
W. H. Heydt
Fri Jun 03, 2016 4:06 pm
No. The display controller has a USB-A port that can be used to power the attached Pi. (That's the way I do it.)
alphanumeric
Fri Jun 03, 2016 4:25 pm
You can also power your PI from the display board using two of the jumper wires via the +5 V and Ground pins to the appropriate pins on the Pi's GPIO header.
6by9
Fri Jun 03, 2016 4:28 pm
alphanumeric wrote:
W. H. Heydt wrote:
6by9 wrote:Unless you want to power your Pi via the display to save a power supply.
And that's the way I do it. At least you can then see the thickness of the conductors.
