InvernessTMD
Upside down..
Sat Oct 31, 2015 1:49 pm
Hi all,
My touchscreen arrived this morning and I have connected it up carefully, using the GPIO pins for power, and when I first powered it all up the screen worked fine, though the touch didn't seem to work. I then did the update and upgrade and when I did the reboot the screen is now upside down and doesn't load all the way up (I have it set to auto log in, Raspbian)...
I am guessing that the cables for the adaptor board are at the top of the screen...?
TIA
AndyD
Re: Upside down..
Sat Oct 31, 2015 1:52 pm
Have a look here. The screen was originally upside down and an update turned it up the correct way. Hope that helps.
InvernessTMD
Re: Upside down..
Sat Oct 31, 2015 1:59 pm
Ta!
Still doesn't sort the not loading issue!
JimmyN
Re: Upside down..
Sat Oct 31, 2015 4:23 pm
To get an answer to that you'll need to explain what "it doesn't load all the way up" means.
InvernessTMD
Re: Upside down..
Sat Oct 31, 2015 5:25 pm
It scrolls through everything, but comes up with a warning about low memory then goes to a blank screen with just a flashing _ at the top left and if you hit enter it moves down the screen with nothing happening.
