piplayer
Getting it working
Sat Oct 10, 2015 11:10 pm
Can't get the display working.
1. Should it be recognised out of the box or do I need to enable it via software ?
2. Is there anything I can look for in DMESG to indicate it has been recognised by the OS ?
3. Do the 2 extra female to female jumper wires included in the display but not mentioned in the documentation need to be connected for the display to light up and show a sign of life.
4. Are these for the digitizer only ?
5. Are there any diagnostic LED's on the display controller board to indicate it has power ?
6. Normally I blow off the noobs software from the official the Raspberry Pi SD cards as I find that it confusing and that it makes bad assumptions however with this Pi I thought it would give it a go. Is there anything in noobs that would stop the display working ie forcing output to HDMI ?
7. Could enabling the camera or enabling SPI via raspi-config be creating a conflict.
I am using a new out-of-the box Pi that has had nothing run on it but raspi-config and upgrading yesterday to latest OS and packages.
Thanks,
Mike
gadgetoid
Re: Getting it working
Mon Oct 12, 2015 3:44 pm
1. It depends on which version of the software you use. Grab the new Raspbian Jessie for everything-enabled-and-good-to-goness
2. Probably. lsmod should show a "rpi_ft5406" module for the touchscreen
3. Yes, connect the power supply to the display and use these cables from the 5V / GND of the driver board to power your Pi over GPIO
4. Oh you mean the EXTRA ones. They're only relevant if you have an old Model A or B. But the software isn't up to scratch for those yet anyway.
5. Nope! Unfortunately.
6. Use Raspbian Jessie.
7. Nope
See also: https://www.raspberrypi.org/documentation/hardware/display/troubleshooting.md
Return to “Official Foundation Display”
