nlrb
Mouse driver problem
Sat Oct 03, 2015 7:47 pm
When using the touchscreen with X Windows the positioning is accurate (i.e. cursor shown where the screen is touched). I guess this uses the event device.
However, when using the mouse device the positioning is quite erratic and not accurate. Below example code using pygame.
import sys, pygame, time
from pygame.locals import *
pygame.init()
size = width, height = 800, 480
screen = pygame.display.set_mode(size, pygame.FULLSCREEN)
while True:
	for event in pygame.event.get():
		if event.type == pygame.MOUSEBUTTONDOWN:
			pygame.display.update()
		if event.type == KEYDOWN:
			if event.key == K_ESCAPE:
				sys.exit()
	time.sleep(0.1)
BTW: I used this code with the PiTFT and that worked well.
Do others experience the same? Or is something else going on? Any remedy?
nlrb
Re: Mouse driver problem
Wed Oct 07, 2015 7:37 pm
Has anybody been able to try the above code? And does it give the same result as for me?
markmagness
Tue Oct 20, 2015 10:58 am
I'm also having this issue with the official touchscreen and pygame, the pointer position does not match up with my finger position. How do we fix?
gadgetoid
Wed Oct 21, 2015 1:53 pm
This is an extreme work in progress, but this library and example show 10 point multitouch working in PyGame and it seems pretty accurate ( although hitting pixel 799,479 with my finger is proving to be difficult! )
https://github.com/pimoroni/python-multitouch
nlrb
Wed Oct 21, 2015 5:06 pm
@markmagness: thanks for confirming it is a generic issue!
@gadgetoid: thanks for providing the workaround via the event interface. However, I don't need multi-touch - I'd just want the mouse interface to work properly. Does anyone have a pointer to how to fix that?
Return to “Official Foundation Display”
