MikeDunn
Screen resolution query
Mon Sep 28, 2015 5:08 pm
Been trying to get an app to play nicely with my Pi2 & official touchscreen, and have wandered into the Display Settings area of Preferences. I'm a little surprised not to see the quoted resolution, but instead am told it's 752x448 :o
Is this right ? Surely my Pi has (somehow) managed to not go into full res ? How can I get the quoted 800x480 ?
Mike
gadgetoid
Re: Screen resolution query
Mon Sep 28, 2015 5:19 pm
I have a feeling that this is very closely related to this: viewtopic.php?f=108&t=121781
I could certainly imagine an incorrect screen resolution throwing off the touchscreen which will be correctly set to 800x480!
Although I've no idea why it happens! It could be a flaky DSI ribbon cable connection causing a failure to detect the screen properly, but that's a guess at best.
A little digging found this: viewtopic.php?f=63&t=120260
This could be worth a try:
FlyingKipper wrote:Yes you have Overscan setting enabled.
run raspi-config
then select Advanced Options -> Overscan -> Disable
MikeDunn
Mon Sep 28, 2015 6:03 pm
That's fixed it :D Now to check the touch aspect !
Cheers !!!
Mike
freekert
Thu Oct 01, 2015 7:45 pm
Same here! Touch was off-set, black bars all around the screen, disabling overscan fixed it. Re-enabling (and rebooting) and it is still fixed. Strange... but it is fixed now.
Thanx for the suggestions!
