doczoidberg
Touch problems with the official RPi display
Fri Sep 25, 2015 9:20 am
I put all the parts together like in the instructions.
Installed latest Raspian and updated & upgraded.
Everything works fine.
But after maybe 30 sec or a minute, the arrow starts hopping up and down (maybe a cm) in the lower middle of the screen.
I cant really use other devices while this happens. (Mouse or keyboard with touchpanel)
I tried to reinstall the system, checked the cabels and tried different versions of she power supply.
Nothing helped.
Does someone have any solution or help?
Re: Touch problems with the official RPi display
Fri Sep 25, 2015 9:44 am
doczoidberg wrote:I put all the parts together like in the instructions.
Nothing helped.
viewtopic.php?f=108&t=121576
Retired disgracefully.....
PeterO
Fri Sep 25, 2015 11:23 am
Nothing helped.
New firmware fixes the touch screen becoming unresponsive which does not sound like the symptoms described here.
I would be double checking that the smaller of the two cables onto the display driver board is fully inserted into its socket.
PeterO
doczoidberg
Sun Sep 27, 2015 3:31 pm
I checked the small cable more than one time.
If it is the cable, wouldn't the problem be there immedeatly?
Not after maybe a minute.
If its the cable why is it working for at least 30 secs?
You know what I mean
Return to “Official Foundation Display”
