Touchscreen mounting screws
Posted: Sun Sep 20, 2015 12:01 pm
by murratw
Can anybody tell me which size screw threads work with the four mounting points on the back of the screen?
Also, are there any drawings of the screen available?
Re: Touchscreen mounting screws
Posted: Mon Sep 21, 2015 9:24 am
by gsh
Check out the documentation
https://www.raspberrypi.org/documentati ... /Readme.md
There's a link to the mech spec, the screws are M2.5
Posted: Mon Sep 21, 2015 12:15 pm
by JimmyN
It depends on which mounting points you're asking about. The inner mounting points for the display adapter use M2.5. The outer mounting points for a stand/case/frame are larger and need M3.0 screws.
Posted: Fri Oct 09, 2015 3:08 pm
by solar3000
I'm a little late on this but I just got my display and I'm using those screws found when you buy a new PC compatible motherboard.
