As I'm eperimenting with various configurations, I wanted to have the RPi board separate from the display mounting.
This could also be useful for those needing to use a more elderly RPi which doesn't have the requisite mounting holes.
So a test with one of my camera board extended ribbon cables works fine as seen in attached pic'.
It also means that a lower profile case could be used or made, with RPi board by the side of the display module rather than on top of it.
Additionally, there's then no need for the stand-offs; just screws to hold the module, thus allowing a lower profile case.
