rockman55
New 7 Inch Raspberry Pi Touchscreen
Tue Sep 15, 2015 9:24 pm
I have just installed the new Raspberry Pi 7 inch touchscreen and when I use the Raspbian software everything seems to function properly, however when I load up with Ubuntu Mate the display functions but without the touch part. Any suggestions or missing information?
gsh
Re: New 7 Inch Raspberry Pi Touchscreen
Wed Sep 16, 2015 5:57 am
It requires an update to the firmware for Ubuntu, please contact the Ubuntu distribution people for this...
Gordon Hollingworth PhD
limpens
Wed Sep 16, 2015 6:41 am
Hi Gordon,
Are there any kernel specific options which should be enabled to use the display?
When I use a recent firmware, with a kernel compiled using buildroot, I do see the splash screen, but no console output.
gsh
Wed Sep 16, 2015 7:03 am
No there are no options required to make it go to the LCD... If you are seeing a splash screen this means the LCD is working... I would suspect the buildroot more...
What happens if you unplug the LCD and plug in an HDMI, does it work faultlessly?
Gordon
limpens
Wed Sep 16, 2015 7:22 am
When connected to a HDMI display, I notice exactly the same. The blown-up coloured pixels are shown, no console messages.
I'll compare the kernel configurations to find a solution. Thank you.
Eric
PaulFinch
Wed Sep 16, 2015 7:26 am
It looks like the rotate_diplay config doesnt rotate the 'touch' function. Someone noticed that too ?
(I cant manually rotate i'm using the pimoroni stand)
PaulFinch
Wed Sep 16, 2015 8:37 am
Looks like lcd_rotate=2 work better
john4663
Wed Sep 16, 2015 8:42 am
Yes Paul, "display_rotate=2" only rotates the display, not the touch area.
Other posts have said to use "lcd_rotate=2" instead, but for some reason it is ignored on my system.
I've done a "sudo apt-get update" and "sudo apt-get upgrade" but it still ignores the setting. My guess is that its not updating the boot loader correctly but I don't know how to solve it. My system is basic raspbian (05-05-2015).
If you get it working, please let me know what you did.
PeterO
Wed Sep 16, 2015 8:58 am
New firmware available via rpi-update fixes a touch screen issue and in might be the thing that implements lcd_rotate as well (as they changed the default to "upside down" :D )
PeterO
limpens
Wed Sep 16, 2015 12:15 pm
limpens wrote:When connected to a HDMI display, I notice exactly the same. The blown-up coloured pixels are shown, no console messages.
Eric
I was building for the RPI2, while using a B+. Sorry for the inconvenience.
Using the (buildroot supplied) raspberry_defconfig the compiled rootfs and kernel work fine.
