psyxche
Using two audio devices in device tree
Sat Aug 31, 2019 11:50 pm
Hello, I'm been planning a project utilizing a Fe-Pi V2 and Justboom DAC HAT. However, I've come into a slump on trying to have the Raspberry Pi, specifically alsamixer, recognize both audio devices. With dtoverlay on config.txt, I can have either card recognized by itself, but not both. Is there anything I can do to try and have both cards recognized?
Thank you.
Peakoverload
Re: Using two audio devices in device tree
Tue Sep 03, 2019 9:16 am
I'm not familiar with either board and am a total newbie so I may be completely wrong but I had the exact problem using different devices and found on here that it is because you can only have one I2C device. If you try to install two, they conflict with each other and only one will work.
Tue Sep 03, 2019 10:47 am
You can have many i2c devices as long as they have different addresses. There are around 126 addresses available on each i2c bus.
To check if you have an address conflict, try connecting just one board at a time and run
i2cdetect -y 1
You will get output similar to this
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- 75 -- --
In this case the device is using address 75.
PhilE
Tue Sep 03, 2019 11:27 am
The likely problem with using two audio devices is the fact that the audio overlays all(?) place the definition of the sound card in the same DT node - /soc/sound - so each additional overlay overwrites any predecessors, at least partially. There's no technical reason why this should be the case, it just seemed tidier at the time rather than have each overlay choose its own place, and it wasn't envisioned that multiple cards would be used together.
To solve the problem you would need a custom version of one of the overlays - instead of:
		target = <&sound>;
		__overlay__ {
you would need something like:
		target-path = "/soc";
		__overlay__ {
			sound2 {
where the body of the fragment has been wrapped in a new "sound2" node.
You may find there are runtime restrictions that mean you can't use more than one device at a time - there is only one I2S bus and controller after all - but there isn't much we can do about that.
Return to “Device Tree”
